Low End Torque
Discussion in 'The Garage' started by Z3PR, Feb 24, 2003.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    What have you done to increase Low End Torque in your Small Block Chevy ???
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Dual Exhaust
    MSD, this doesn't increase low end torque, but it improves throttle response so it feels like more low end torque and make life a little easier when offroading.
  3. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    Those 400 small blocks had quite a bit of torque off the showroom floor, compared to most. Anything to help the motor breath easier should help. A good tuned carb, good spark plugs and you should be good to go. I feel your pain. I wish I had more low end grunt.
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I'm about to build my 350 in my c-10 for pure torque...
    Got the exhaust, headers, mufflers....going with a performer intake, and a new cam.....I hear something around a 268 would make ideal pulling torque in a mild engine....hext will be a throttle body to add to the MSD response...
  5. dkodyssey
    dkodyssey Registered Member
    Feb 22, 2003
    40
    otisville,ny
    comp cams makes a 4x4 camt hat is supposed to be good for torque.its goin in my 350 when i build one up.
  6. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    advanced my cam 4*.... /forums/images/graemlins/grin.gif Really like it!
    Marv
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Ways to improve low end torque:
    shorter rods (SBC 400)
    Low-rise dual plane manifold
    re curve distributor
    small primary headers
    well tuned carb
    open element air cleaner
    matched cam (for that matter ALL engine componetns) for desired engine RPM's
    if you want low end torque, you don't put a Victor Jr. manifold on a engine with a RV cam.
    Nor do you put a stock TBI on a 600HP motor with .500" lift on the cam and 12:1 compression.
    Match your engines components for what you want to achieve
    Marv, tell us more on this cam advance. I have heard of degreeing in a cam during installation, is that what you did?
  8. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Degree-ing the cam is basically just checking the advertised dimensions of the cam with a measurement device (dial indicator) and making sure that there are no "installation" factors that give you false valve timing. But as far as "advancing/retarding" the cam, the rule of /forums/images/graemlins/thumb.gif is that advancing helps low end torque while retarding helps the volumetric efficiency at faster engine speeds.
    My engine is all stock except Vortec heads and a 204/214 Summit cam that's advanced 4*. This is the 3rd small block I've had in the Green thing, and I have to say that I think it's the best performer. The last motor ran a Crane 272 (214/228) straight up, and World Products Torquer (way more $$ than the Vortecs) heads and, although it may have had a little more on the top end, I rarely used it....
    Marv
  9. blazen_md
    blazen_md 1/2 ton status
    Aug 20, 2001
    129
    MD
    I run the stock air intake setup on my 90k5 with a K&N filter packed inside will I notice a big difference if I switch to open element K&N????
  10. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Like said earlier make ALL of your components match and make sure your cam grind is of short durration at .050 , as much lift as the profile will allow , and has exceptional cylinder pressure down low .
  11. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I like the idea of advancing the cam.... Might have to look into that. /forums/images/graemlins/tongue.gif
  12. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    THORLEY HEADERS!!!! There GREAT!!!
  13. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Kicked my wife out of the truck! /forums/images/graemlins/rotfl.gif
  14. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  15. sidslc
    sidslc Registered Member
    May 27, 2002
    96
    slc ut
    replaced it with a 502 /forums/images/graemlins/cool.gif
  16. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Would love too, wanta buy me one ???
  17. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Stroked my 400 to a 415 and set it up for RV/Towing. Lots of drivetrain busting torque, great gas mileage!
  18. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    Got a 400 smallblock to a 406, Tri-Y Doug Thorley headers are the best mod you can make. Air filter, tuned carb and a cam. I hear cams are a night and day difference in a smallblock, hopefully I'll find out soon. /forums/images/graemlins/truck.gif
  19. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] I've got a 400. Can you hook up a link to information on the 415 stroker kit ???
