LOW OIL PRESSURE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SHAWNSTER, Jan 29, 2004.
  1. SHAWNSTER
    SHAWNSTER 1/2 ton status
    Sep 24, 2002
    211
    DALLAS,TX
    my tbi 350 sits at 30 psi almost all the time when warm-when cold it sits at 25psi-its got almost 200k miles on it though-whats the deal-i still have plenty of power in the motor-thanks for help in advance
  2. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    Thats plenty of pressure... /forums/images/graemlins/thumb.gif a stock/mild 350 only requires 10 psi at idle to suffeciantly lube the engine.... 25 at idle and 30 running is great... unless you have a high pressure pump
  3. SHAWNSTER
    Sep 24, 2002
    211
    DALLAS,TX
    thanks for the info-the reason i asked-i read an article in a mag that was basically saying somthing is wrong if under 30 psi-
  4. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    With that amount of miles, it probably would be a good idea to replace the oil pump with a high volume. Oil pressure is directly affected by what kind of tolerance, or clearance exists in your main bearings, and Cam shaft bearings. /forums/images/graemlins/thinking.gif
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    They (pros) recon that under SEVERE running conditions (racing) that you need 10psi per 1000rpm. So I recon your pretty safe. I have little more on my '91 with 155000 on the clock and it's as sweet as a nut! /forums/images/graemlins/thumb.gif
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I thought the 10psi per 1,000RPM was for any motor? Only for racing?
    Get a melling high volume pump, I have 30psi at idle and it jumps to 60psi and pegs the guage above 2,500rpm's /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    They recon that's what you need if you're going to punish the motor. A by product of high pressure is heat as your pumping more than you need under normal conditions and the pumping causes pressure/friction and therefor heat! But with reg oil changes, the likes of you and I would never know the difference! /forums/images/graemlins/thumb.gif
  8. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Well I gots close to 200k on mine and when hot at idle I have almost 10psi and 40psi when on the throttle.Cold I have 60psi at idle/forums/images/graemlins/grin.gif
    I dont like that the oil press is that low at idle when warm but as long as the lifters n stuff aint makin noise,I aint worried /forums/images/graemlins/tongue.gif
  9. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Your pressure is low because your bearing clearances are getting larger due to normal wear and you have 200k on it. If your worryed about it get a M55HV melling high volume oil pump ($25 w/ pickup Autozone) to make up for the increase in the bearing clearances. You probably need a new pump drive shaft because when you take your stock one out likely the plastic sleeve will blow up. You can find a steel sleeved shaft for about $12.
  10. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Geez, i have an 89 Burb with the TBI 350 and 210k miles and is always runnin at 45-65 psi. But then again i change my oil about every 2500 just to try to keep up on the higher mileage engine and hopefully keep it lasting longer.
  11. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    lucky dawg, the last 3 months of my old engine life it had 45psi cold, 25psi goin down the highway warm, 0 at idle warm.......wasnt pretty sounds but i was already building its replacement......hell im still building. argh
