Low preload on old pinion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zhgrou6, Aug 13, 2005.
  1. zhgrou6
    zhgrou6 Registered Member
    Dec 28, 2003
    12
    NY Finger Lakes
    I am starting to replace the pinion seal on my 1985 K4 rear axle. I measured the preload rotational torque to be 1.2 in lb CW and 1.1 CCW. Seems too low. Spec I found in another thread is: Pinion bearing preload new 20-25 in. lbs. / used 5-15 in. lbs. I measured with rear wheels and drums off. Pinion shaft has no play sideways or in and out. I can feel some back lash when I turn the pinion yoke, normal. When I reassemble the pinion I'll try to return to same rotation torque adding 1 to 5 in lbs for drag caused by new seal (according to Haynes manual). Perhaps my preload is so low because my gear lube is low. That's why I'm replacing the seal. Any comments?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    i usually set the preload with no fluid in it so...not sure that that has anything to do with it. sounds very low to be 1.1 in lbs...not sure why...maybe seal worn...bearings worn...any other ideas?
    ryan
  3. zhgrou6
    Dec 28, 2003
    12
    NY Finger Lakes
    Seal was destroyed
    Worn seal - yeah, when I removed the yoke I found the rubber part of the seal just hanging on the shaft. It was completly detatched from the seal shell. So if resistance from the seal is part of the preload torque spec - I had none. That could explain the low preload torque I measured.
  4. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    gm tech told me to take chisle and hammer and marke end of pinon shaft and nut. remove nut do work and put back on and have nut mark just past pinon mark by a hair. works great for him over the years.
  5. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    I can't help with the preload, but I am curious as to what a K4 is? :D
