LOW RANGE!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by teufel_hunden25, Jul 6, 2001.
  1. teufel_hunden25
    teufel_hunden25 Registered Member
    May 26, 2001
    23
    I have a 77 Blazer and the transfer case is stuck in low range 4x4. I can move the shifter but the only time the truck will move is when it's in low range. I need help bad. What causes this? And is this problem what is causing the rig to vibrate like a bed in a cheap motel???
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You need to ID the T-case model for us, that'll make it easier to troubleshoot.
    Sounds like you have a 203 that's crapping out on you. Chain's probably slipping and making the vibration, the not moving is probably related to shifter adjustment.
    Making the world better, one truck at a time.
    [image][/image]
    SW-ORD
  3. teufel_hunden25
    May 26, 2001
    23
    It is in fact a 203. If the chain is slipping what all do I need to do to correct this? If a professional does it what kind of $$$ am I looking at. I may not have the time to fix it as I leave for Marine Corps boot camp in 9 days!
  4. teufel_hunden25
    May 26, 2001
    23
    Any ideas????
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Semper Fi brother! I don't know jack about 203s, but congrats on joining Uncle Sam's Misguided Children!
    Tim
  6. teufel_hunden25
    May 26, 2001
    23
    Thanks, and Semper Fi! I'm lookin forward to making the change. I've wanted it for a good long while, and now I finally get to live it.
  7. teufel_hunden25
    May 26, 2001
    23
    6 days til I leave, anyone have any ideas as to how much this should cost me (if done professionally)?
  8. It will cost you way too much to have a shop overhaul your 203 t-case. You should either buy a good used 203 for $100.00 on up, or opt to put a 205 t-case in it. I bought a 205 for my 77 SWB for $150.00 from the wrecking yard.
    Later, Doug
    4 wheelin's not a job, it's an adventure!
  9. teufel_hunden25
    May 26, 2001
    23
    Thanks for the advice. I should hear word as to what the shop says is the problem tomorrow. Hopefully I can have this thing on the road in the next 6 days!
