Low RPM miss when warm
Discussion in 'The Garage' started by MTBLAZER89, Jul 24, 2006.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    On a TBI 454. It was much more pronounced as the motor got hotter and towing. It seems to go away in 3rd gear around 35-40 MPH. It does not do it when it is cold at all. No codes either.
    Any ideas on where to look first?
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    It sure sounds like a bad plug wire or ignition component to me. They always show up under load, at operating temperature or hotter, and can disappear at cruising speeds. I'd take a few minutes and check the wires first.....
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Thats what I was thinking wires or dist issue.
  4. Can Can
    15,552
    136
    My K5 had the EXACT same issue quite a while ago. It ended up being ONE bad wire, and it only showed up during acceleration after the truck had warmed up.
    Let us know what you find.
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    will do
