low t case fluid
Discussion in 'The Garage' started by TxK5Blazer, Dec 22, 2003.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    would a np208 low on fluid having been run for a while with out fluid cause a wicked vibration....Jason
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I would think so. But others can give you a more definitive answer.
    John
  3. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    TTT I need some input from the Gurus in here before I run off and buy another t case guys. Thanks in advance for your help.....Jason
  4. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    bump ttt once again
  5. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    49 views and all I get is one response come on guys I just need some opinions here before I swap cases...Jason
  6. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    Hey Jason i am sure lots of us would like to help ya but you dont really give us enough info
    there are so many things that cause a " wicked vibration
    Drive shaft con dition and angle being #1 on my list
    then tires then
    ball joints then alinment
    etc etc etc
    give us more specific info and we might be able to at least make a educated guess
    example what speed it starts at
    aalso have ya jacked up andd secured the truck and tried it with all the tires in the air yet with a buddy watching ??
    good luck
    R
  7. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    ok lets see what you guys can do with this info. Front end aligned. all new tre's and dle's also. Ball joints good. rear drive shaft doesn't look bent and replaced both u joints. I was getting a small vibe from driveshaft then lowered transfer case and vibe went away. all four tires have been balanced and then replaced for new one for possible out of round tires don't think it is the tires had them for almost a year and the wicked vibe just started a week ago. any speed over 40 it vibes gets worse the faster you go. I checked the fluid in the case last sat. and I added 2.5 quarts to it and drove it the vibe was gone I know the case has a leak but didnt' think it was that bad. I now noticed that yesterday the vibe is back will check the fluid level again and see it that could be the problem....Jason
