Lower Gears
Discussion in 'The Garage' started by jayccb, Feb 12, 2005.
  1. jayccb
    jayccb Registered Member
    Dec 26, 2003
    18
    wisconsin
    wHAT CAN i EXPECT if I change the gears? I currently am running 3.4? with 35" tires and a stock 350. I replaced the 10 bolt with another 10 bolt when it blew up last year. Will it be quicker off the line? What could I expect on the highway with the lower gears and how might it affect towing?
    James
  2. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    You left out some information. You originally had 3.42 gears but you didnt tell us what ratio you replaced it with.
    -Harrison
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    quicker off line would need shorter tires/deeper gears/higher stall converter
  4. goldwing2000
    goldwing2000 Guest
    If you were to go to, say, a 4.11:1 gearset, you would have better acceleration, lower top speed and higher RPM on the freeway. Towing would be improved because it would be easier to get the power to the road.
    If you check out this chart, it will give you an idea of where you want to be.
    You're running the same combination I am, and I'm planning on going to a 4.11, maybe a 4.56 if I'm feeling saucy.
  5. 87BrnRsd
    Apr 21, 2003
    2,457
    Like others said, you will get more torque and acceleration but will turn higher rpm's on the highway. Going from 3.42 to 4.10 would be a noticeable change. If you went to 3.73, it wouldnt really make a huge difference.
    -Harrison
