Lower kingpin cap bolt
Discussion in 'The Garage' started by pomai, Feb 24, 2005.
  1. pomai
    pomai 1/2 ton status Premium Member
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    Broke 2 of the lower kinpin bearing cap bolts on my Dana 60 tonight. :( Has anyone ever broke these before?
    Any sugustions on how to remove them?
    How much heat can I put on them and what area should I concentrate the heat on?
    Thanks Ed
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i would try w/ out heat. drill the bolt w/ a left handed drill bit & if that doesn't get it out try an e-z-out. i would use heat as only a last alternative.
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Try what he said but use some pb blaster too, shouldnt be to hard to get out
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I broke a bolt off in the top part of the knuckle and it was siezed BIG TIME! I took it to a local machine shop and they drilled it out and installed a full-length Heli-Coil for $15. I was a little concerned about the Heli Coil idea but called Stephen at ORD and he said that was the best option I had. 8 months later, all is well!!!
