Lower Transfer Case HELP
Discussion in 'The Garage' started by ditavonteez, Jan 15, 2004.
  1. ditavonteez
    ditavonteez Newbie
    Jan 15, 2004
    They tell me that on my 1978 chevy blazer that i have a 4 inch lift on that i need to lower my transfer case.... but is that bad for my engine and carburetor..? /forums/images/graemlins/rolleyes.gif <font color="red"> </font>
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    It's to correct driveline angles. But that can be corrected with CV style rear drive line.
    Bill
  3. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    The engine will tilt a little more in the aft. It shouldnt be a problem for the carb. Dropping the case will reduce the severe angle at the driveshaft/transfercase u-joint and usually helps reduce or eliminate vibrations caused by the severe angle. CV setups are nice but cost some $$$. Dropping the case is a very simple procedure.
    Heres a link on Driveshaft angles
    There is also a kit for dropping the xfercase which includes full-length blocks which will prevent possible cracking of the frame instead of moving the stock spacers around. I didnt use them (yet) but probably will switch over in the future. You can see a photo of a dropped case on my Blazer link
  4. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    If its not making the rear shaft vibrate do not lower the case. Assuming your '73 has an NP203, and thus a fixed rear output, it should not need a dropped case w/ a 4" lift. If you are going to drop the case 1" why didn't you just put on a 3" lift? Just something to think about. If you do drop it your carb should be fine but be careful w/ the dist. cap. It is also bad for the motor mounts and the frame in the area near the trans x-member.
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I agree with 88silverado.Get the kit and don't use the stock spacers...take it from someone that used the stock spacers and cracked the frame. I had to reinforce the frame at the crossmember after only a couple of months with it dropped 1".
