Lowered my sway bar and i think it helps the ride....
Discussion in 'The Garage' started by 88K5Jimmy, Apr 11, 2004.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    In my constant pursuit to make the front end not bounce so much, I have already removed the lower leaf on my 6" BDS springs. While this helped, I still wasn't satisfied with the ride in the front. I currently have the ORD sway bar disconnects so I figured my sway bar was lowered enough to compensate for the 6" lift. The I decided to unhook the sway bar and give it a ride. While it didn't bounce as much, I didn't like the feel of it going all over the road. I could definitely tell the sway bar was unhooked. Then I got to looking at how the swaybar was hanging from the front mounts and realized the rear of the sway bar could be moved up a bit. Sitting as it was with it hooked up to the ORD disconnects, it looked like it could be causing it to bind. So I had some 1 1/2" square tubing laying around and I decided to cut two pieces the same length as the front sway bra brackets and bolt them in. A little cutting and painting later, I had dropped the front of my sway bar another 1 1/2". I also drilled two holes in the front sway bar brackets and bushings and installed some grease zerks. I think the 80 miles I drove back to college today worked the grease around the sway bar and accomplished a somewhat smoother ride. Of course it still drives like a lifted leaf spring truck but I think I accomplished something. Next might be some adjustable shock or maybe different springs /forums/images/graemlins/thinking.gif
    If you want pics I can take some, just thought I would share and maybe give someone a idea. /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif
  2. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    pics plz
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I took my swaybar off and threw it in the corner. Truck rides much better now than ever.
  4. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    I'll take some tomorrow /forums/images/graemlins/peace.gif
  5. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
  6. unick
    Aug 16, 2003
    4,286
    cool thanx man /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  7. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    No problem
