lowered Xcase pics
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Dec 19, 2001.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    does anyone have pictures of a lowered transfer case to see how it looks like. I believe mine is already lowered however i really doubt it. where are these "oem" 1 inch spacers everyones talking about?
    lost and confused as usual
    phill
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I don't have any pics but it's pretty simple. Your t-case cross member should be flush against your frame if it's already dropped. Place a jack underneath the cross member, loosen the bolts and remove them. Along with the bolt, nut and washer there should be a 1" sleeve. Drop your crossmember a little bit, place the sleeve between the frame and cross member, replace the bolt and nut x 4 and thats it. Mine didn't have the sleeves on all the bolts so I stacked washers. Same effect.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  3. surg82k5
    surg82k5 1/2 ton status
    Feb 7, 2001
    416
    San Antonio,Texas
    If you are going to the Austin K5 convention off of Oltorf I will be there and you can look at the bottom of my blazer.
    Sergio
    Check out my new website. <a target="_blank" href=http://www.surg82k5.rockcrawler.com>http://www.surg82k5.rockcrawler.com</a>
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I didnt use the factory spacers I just used some flat stock.You can see it in the upper right corner of this pic community.webshots.com/user/beaterwhang
  5. shupach
    Dec 28, 2000
    648
    Dallas, TX
    when and where is it? might drive down if i have time
    phill
  6. surg82k5
    Feb 7, 2001
    416
    San Antonio,Texas
    It is tomorrow at 6:30 PM at the clicks Billards off of Oltorf, not very hard to find at all, I can give you my cell # if you need directions just call, e-mail me at surg7498@yahoo.com to let me know if you are going, if not just call me at 512-775-9084cell hope to see you there,
    Sergio
  7. shupach
    Dec 28, 2000
    648
    Dallas, TX
    ya idunno if i can make it, being 17 i kinda hafta ask the parents if i can go down, who knows maybe they'll be in a good mood.
    phill
