lowering 3/4 ton pickup
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kiley, Sep 10, 2002.
  1. kiley
    kiley Registered Member
    Mar 5, 2001
    87
    Salem, Oregon
    I'm getting a 71 c20. Where should I look for a 2 inch lowering kit, probably spindles in front and I need suggestions for the back.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    For the rear, flip the axle, will get you an instant 3 to 4 inch drop.
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    is it coils in the rear?? if it is then you have the prime set up for some air bags. if it is leafs just throw in a 2" block or the "low rider"shackles that are made by ground force and bell tech.
    summit sells one too.
  4. Captkaos
    Captkaos 1/2 ton status
    198
    Birmingham, AL
    If you flip the back (assuming leafs) it will drop it over 5".... If you only want 2 in the back, get shackles, up to 4, add a hanger to that. For the front, get spindles. If you have coils, get lowering springs (check with http://www.earlyclassics.com )
  5. kiley
    Mar 5, 2001
    87
    Salem, Oregon
    nobody makes spindles for 3/4 ton trucks.
  6. kiley
    Mar 5, 2001
    87
    Salem, Oregon
    It does have coil springs. Any recommendations where to look for air bags?
