Lowering a 3" Body lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Boss, Mar 6, 2000.
  1. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Lowering a 3\" Body lift?
    Ok guys,
    I read some post in the past about body lifts and how most of yall don't recommend it. Also I think it was GoldRush that said If you own a Pre 76' Blazer, you should not install a body lift b/c of the weak body structure or something like that. Anyways, I have a 3" body lift on my 75' and now I'm thinking that maybe I should lower it to 1" lift or 2". I know 2" aint really that much of a difference, but 1" seems to be. My question is, is it worth it and how hard is it? Would I have to change up anything. I did not put this lift on myself. Also, the reason why I don't want to get rid of the body lift all together is b/c I have 35" meats and don't want to rub or cut fenders. I may or may not do this depending on difficulty, but I am just wondering. Thanks.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Re: Lowering a 3\" Body lift?
    1st thing that comes to mind would bee your steering shaft.
    How was your steering shaft lengthend? If it was streached then welded you will need a new one.
    Try to emaigine looking aound the rig and everything that goes from the frame to the body will be affected in some way , gas tank filler,gear shifters,cluch linkage, break lines. of corse your going the opiste so its a matter of re-routing or tucking up....
    good luck
    Rock ON!
