Lowering a transfer case on a Crew Cab...?
Discussion in 'The Garage' started by 1-ton, Oct 14, 2005.
  1. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    I have a small amount of drive shaft vibration on my 1-ton Crew Cab 4X4 at 15 and 35 MPH. I want to lower my transfer case, after I have taken some driveline angle measurements, to stop the vibration. My truck is a long wheelbase Crew Cab 4X4 with a carrier bearing behind the transfer case. I was wondering if just lowering the carrier bearing would do it, or would I need to lower both the transfer case and the carrier bearing? Anybody have any suggestions on this?
  2. 425 Xpedition
    425 Xpedition 1/2 ton status
    Dec 4, 2001
    123
    Crosby, Texas
    I lowered the carrier bearing on mine and cured the vibrations.
  3. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    COOL :laugh:! That will be a "piece of cake". Just throw a few washers (or maybe a piece of plate steel) between the bearing and frame, and I'm good to go. Thanks for the reply!
  4. ccj8008
    ccj8008 1/2 ton status
    Apr 2, 2001
    228
    Polson MT
    Itook a piece of 3x3 square tube, drilled 4 holes and used it to lower the carrier bearing. Worked for me (6" lift).
  5. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    WOW! 3" is a lot of correction. I am thinking I will only need between 1" and 2" at most. I am think of using some pieces of flat steel, and just drill a couple of holes in it, then sandwinch them between the bearing and frame, in order to drop my carrier bearing.
