lowering radiator
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lowharley, May 2, 2003.
  1. lowharley
    lowharley Registered Member
    Feb 18, 2003
    20
    Has anyone lowered the radiator after installing a body lift? If so, how?
  2. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I am guessing it would involve a bit of fabricating as you would have to cut out the bottom of your core support, then make braces to reconnect it lower. Then you'd need to make some kind of brackets to hold the top of the radiator.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    All i did when i did my body lift was cut the fan shroud in half, formed some thin gauge stainless steel to the shape of the shroud and screwed it back together.
  4. lowharley
    Feb 18, 2003
    20
    I was thinking of doing something similar. Do you have any overheating problems? Isn't the fan 3" lower on the radiator than stock.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Well on mine its 2" lower (I only have a 2" body lift) no, i have no overheating problems what so ever. When the body lift is all said and done, if you look through the front under the bumper, you will also see a gap there, my intention is to fill that in also (just haven't had time yet) that way all air goes into the rad through the grill like normal. But for now, i haven't had any issues and i've had my body lift on for about a year now /forums/images/graemlins/thumb.gif
