lowering shackles for lift?
Discussion in 'The Garage' started by 74757685k5, Feb 28, 2005.
  1. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    i have a cheap shackl flip (cut out bottom of hanger). would lowering shackles make it so i could run 56's? my rig is '76 400/350/203/D44 14FF .:confused:
  2. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    it will work thats what im running just make sure u brace them up real good with either pieces of tubing in the middle or weld in some plate on the sides. with weight on the frame i should have a perfect shackle angle, right now i have a very good angle and with weight it will get alot better. i used sky's flip kit and 56'' stock springs with a 6.5'' shackle.
