Lowering the T-case driveline issues
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Aug 6, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    ok, i understand that lowering the transfer case reduces the angles and distances that the drive shafts have to put up with but wouldnt lowering the tcase have an effect on the engine and trans mounting since they are all connected? Wouldn't it put more stress on the engine mounts?
    Check out my 73 K5 <a target="_blank" href=http://members.theglobe.com/xnoahx/73k5.htm>http://members.theglobe.com/xnoahx/73k5.htm</a>
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    You are only lowering it one in. And look at distance from the t-case to the engine mounts...........Dan
    If it ain't broke.......Don't fix it....
  3. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    How do you lower it anyway? Just spacers?
    "1988 K5 Grand GT Blazer Silverado in the Netherlands."
  4. Yes, it will put a bit more stress on the motor mounts. But if you use the factory supplied spacers then you would only be outting minimal stress on them. So if your worried about it, dont...ITs all good,
    Damn I need to learn how to use my welder!![​IMG]
    (90 Jimmy 350 TBI, 14 FF/10 bolt, 4.56, tires ??
    (ftn96)
  5. Medman74K5
    Medman74K5 Registered Member
    Jun 7, 2001
    48
    Arizona, Prescott Valley
    Last time I atempted to lower my transfer case it pushed my distributor up against the firewall and busted a motor mount. Ended up putting everthing back were it was and got a longer driveline problem resolved, no vibes so far. Just my experience. All trucks are a little different.
  6. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Use the factory spacers. On mine, the passenger side had the spacers on the top of the bolts next to the nuts. On the drivers side, the spacers were under the frame rail near the head of the bolts. Just remove the bolts and the spacers. Lower the t-case just enough for the spacers to fit between the crossmember and the frame rail. Put the bolts back into place with the spacers between the crossmember and frame rail and you're all done. Nothing to it.
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
  7. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Did it this weekend. I had thought about the added stress on the motor mounts but it didnt look as crooked as I thought it would be. there are little drum spaces on the bolts hold the case to the frame. Take your jack and place it under the t-case. Remove the bolts and slowly drop the case down just enough to get the spacers back in. For shieets&amp;giggles check your clearances of your distributer. We didnt have a problem. It wasnt HEI so it was a tad smaller. just to double check we fastened the stuff abck to gether and cranked the engine. No bump, rub, or breaks. It does take more elbow grease to get the cap off now and I did move the adjust collar around for better acces. I hope this ansewers any questions.
  8. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    This is all great information, thanks for sharing!
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
