Lowering the T-case?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DuneRunner, Feb 25, 2002.
  1. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    How to... What do I need to look for in Lowering my T case?
    I put on the add a leafs this weekend. And I have a slite vibe, and I could see that the slip yoke is out a lot more then normal. Please lend your experience. Thanks O ya Its a 208 on a 700r4.
    Late <font color=green>KEN</font color=green>
    Fremont, CA
    DANGIT it's not a bronco!
    <a target="_blank" href=http://community.webshots.com/user/kensk5>My Picts</a>
  2. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    PLEASE HELP? I have no idea where to look.
    Thanks Guys/Gals
    Fremont, CA
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Ken give me a call tonight at home...If you lost my # pm me and I will give it to you again...Dan
    If it ain't broke.......Don't fix it....
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
  4. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    SWEET in the office today? or just lunch time...
    Sounds good Thanks. Say 530-600 pm. I'm going straight to Marsha's.
    Fremont, CA
  5. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Nothing to it. Do one side at a time. Pull the 2 bolts out, and put the spacer piece of tubing between the frame and crossmember when you do it. Now the tubing is located on the topside of the frame. Guess GM provided it to us for just this purpose. Luck to ya.
    Bryan
    Sherman, Tx
    <font color=red>The blazer's almost on the road....anyone got tree fiddy?</font color=red>
  6. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    SO it is only the cross member that you lower? And nothing on the Tcase itself?
    Fremont, CA
  7. gotmud?
    gotmud? 1/2 ton status
    Feb 23, 2002
    1,172
    up north
    been wondering about this one myself, will this be necessary for a 4 inch lift? sorry for butting in.
  8. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    I would CUZ GoKarterGo (Dan) learned the hard way. His slip yoke broke on him a few weeks ago. His got week before he droped the Tcase on his 4 inch lift. blamOOOO luckly he got to a safe location. With out breaking the entire rear shaft.Something like $150.00 and a new slip yoke. No worrys about your question here.
    Fremont, CA
  9. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    convert it to a fixed yoke then your problem is solved...or just pull thos spacers and put them on the bottom side...its a very easy job to do...maybe 45 mins tops
    <font color=green>Chaz</font color=green>
    [​IMG]<a target="_blank" href=http://community.webshots.com/user/chaz88k5>http://community.webshots.com/user/chaz88k5</a>[​IMG]
  10. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    So it is just a matter of putting the sleves between the frame and the X member? HMMMM Sounds Real easy. Thanks
    Fremont, CA
  11. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    It is easy. But there is a trick to it... Something like the com-a-long trick... You know what I mean...LOL...So give me a call...Dan
  12. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I should be home most of the evening... I am going out right know to check out a 1 ton truck... The guy that told me about said the guy just pulled the motor and is wanting to sell the rest... I am hoping for a D60 and a 14ff... Will let you know tonight...Dan
  13. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    SOUNDS GOOD [​IMG][​IMG]
    Best of luck I'll call around 800pm
    Fremont, CA
  14. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I lowered my trans case and now my motor is on an angle. This is ok when I had a body lift on... but with it off now I almost hit the fire wall... hopefully at flex the cab doesnt hit the distributor!!!! but hell with 14" leafs I dont think there is going to be much flex...
    <a target="_blank" href=http://community.webshots.com/user/rootbreaker>Pics of buildup</a>78 Chevy 3/4 - 14" on 40"x17x16.5 Ground Hawgs
  15. tightwork 82 K5
    tightwork 82 K5 Registered Member
    Oct 15, 2001
    47
    orlando, florida
    I have a six inch lift on mine, I seem to have a vibe at 55+ I think I need to do this drop as well for my drive angle. any sugestions? also looks like the y in my stock exhaust will hit the front drive shaft if I lower the tranny, anyone else have this problem?????
    I got a neon stuck in my grill !!!!
    http://community.webshots.com/user/tightwork
  16. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    You have to extend the front exhaust. Even on a 4in lift.....Dan
  17. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Thanks everyone who helped out with this little problem that I'm faceing. I'm going to look at it tonight.
    Fremont, CA
  18. laketex
    6,220
    North Texas
    I did mine with my 4" shackle flip cause my driveshaft angle was too severe. Wish I didn't have to do it, but it didn't hinder me too much this past weekend. :)
    Sherman, Tx
  19. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Right ON... Doing it tonight. I'm itchen to do it now that I know its so easy. Good to hear that it wasn't a problem. I have probably gained 1.5-2 inches of lift with these add a leafs. New shocks are in store. I'm lucky enought to have Such A GOOD Bud GoKarterGo who hoocked it up with a used set of RS5000s. So two 4" lift shocks are going in the back.
    Fremont, CA
