LOWERING THE TRANSFER CASE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gabdam, Feb 14, 2001.
  1. gabdam
    gabdam Registered Member
    Jan 25, 2001
    26
    NEW YORK
    DO I HAVE TO DROP THE TRANSFER CASE WHEN I DO THE 4" LIFT OR IS THAT ONLY IF I GO HIGHER THAN 4" I'VE HEARD YES I DO AND NO I DON'T WHAT DO YOU THINK??
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Install the lift. Then drive it around the block, and try to get it up above 50 to see if you are going to have any vibrations. If you do have any then lower it.
    Will work for beer, parts and tools.
    90 Jimi,350/700R4/241/10bolts/4.10's/33's/4"
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  3. jerseymudder
    jerseymudder Registered Member
    Feb 13, 2001
    59
    south jersey
    I'M RUNNING AN 86 BLAZER W/4INCH LIFT. I TORTURE MY TRUCK OFF-ROAD & MY SHAFTS TAKE IT "FOR A WHILE". I'M GOING TO TAKE THOSE NICE FACTORY SPACERS & SEE IF THEY ALONE WILL DO THE TRICK.
  4. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    I think it depends on the transmission and transfer case combo you have. The longer the rear shaft the better the angle and the less likley to vibrate. When I was pulling a steering box at a you-pull-it junkyard, I ended up with four extra steering box spacers that I used to drop my crossmember. The price was right and seem to work fine.
    [​IMG]<font color=red> Elkboy</font color=red> [​IMG]
