lowering Transfer case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TheGeneral, May 5, 2001.
  1. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Well, just got the four inch put on with the new axles and all is well. Just wondering if lowering the transfer case about a inch and half would be better for the drivelines, and if I do it, will it cause any undue stress or operating problems with trans (automatic) and engine mounts area. I don't think this has to be done, given it is only a 4 inch lift, but I figured what the hell, if it will help drive line angles without causing any other problems. Hope to hear soon, as I still have alot of stuff disconnected underneath truck. This is on my 89 K5, now with four inch, 14 bolt and dana 60. Pictures soon, as I am now not as embarrassed to post pictures.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  2. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    My 82 K5 Has a 4 Inch Lift And The Transfer Case Had To Be Dropped About 1 Inch To Help The Drive Shaft Angles Work.
    It Did Not Cause Any Problems With My Auto Tranny Or T-Case.
    Daily Driver And Play Toy For 5 Years .
  3. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    My 90 has a 4" lift as well and the T-case is lowered 1". The only thing I get is a little chatter from the clutch when its disengaged. Doesn't seem to hurt it any. (and it may not even be the lowering that caused it now that I think about it) [​IMG]
    Why do people keep calling it a Bronco!!!!! [​IMG]
  4. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    i dont know if there is a difference, but i have a 2wd 14 bolt and an ord shackle flip, and even with the t-case dropped 1 inch, i still had to shim the pinion DOWN 2 1/2 degrees because of the difference in the angles. its better, and although i should go 4 degrees on the pinion, it looks like to much for the yoke to handle so i may drop the t-case another 1/2 inch....has anyone dropped there t-case more than 1"?
    it vibrates aorund 55-60...not nearly as bad as it did, but some
    AIRBORNE!!
  5. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    TheGeneral ~ thats kinda comical because the name of my blazer is "The General"
    it even says it on the windshield
    check it out at my webpage.
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  6. Mudfreak
    Mudfreak 1/2 ton status
    Dec 16, 2000
    116
    NY
    I made my own spacers out of aluminum, they're one inch and work well for relieving the drive line vibes.
  7. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Don't forget that "lowering the transfer case" is somewhat of a misnomer. You are actually tilting the entire engine, transmission, and transfer case down. You need to make sure that you have clearence for your distributor, fan, etc. if you go more than the 1" spacers that are already on the t'case.
    Derf00
    http://www.derf00.coloradok5.com
    "Four wheel drive allows you to get stuck in a more inaccessible place."
  8. TheGeneral
    Feb 22, 2001
    556
    NC, USA
    Everyone, thanks for the info. Since I didn't hear any negative aspects to it, I am going to lower her with the spacers already on the crossmember. I should have the clearance with distributor and I'll have to check fan before turning her over.
    The General
  9. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    I have a 79 with a 4L80E (overdrive) and a NP205, this makes for an even shorter rear drive line. Mine has about 1.5 " spacers I think.
  10. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    azblazer, what did it take to install the 4L80E to the 205? how did you get the computer to hook or did you use a diesel version.
    details please, i am considering this or a NV4500 swap.
    TIA
    Knife.
    knife.coloradok5.com
  11. azblazor
    May 5, 2001
    1,953
    The 4L80E is controlled by a factory computer setup - it was installed with it's 94 454fi. The 205 is mated to the trans with a custom machined adapter. Oh, for the record - I'm AZblazOR not AZblazER - just to keep things on the level. I'm a newguy here. Saudia Arabia Huh? Wow.
  12. azblazor
    May 5, 2001
    1,953
    Knife,
    Also if you need sometime I could take pics.
  13. nyyef
    May 16, 2000
    479
    Saudi Arabia
    actually i have wanted to switch mine to an auto but i want OD. the only problem i am having is over here we dont have that many diesel trucks to take the harness out of. JET sell them for too much.
    i am interested in the adapter that was used to mate the two.
    Knife.
  14. bigjbear
    Feb 18, 2000
    13,973
    454
    Marietta GA
    If you don't have any vibes now don't mess with it. All you will be doing is giving up clearance. That said mine is lowered. It seems to be more necesarry with the slip yoke equipped cases. If you have post lift vibes this is a cheap way to fix it.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
  15. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    General, if your rig is running smooth with no wierd vibes, leave the T-case spacers where they are. They asre only for those of us who have to play with driveline angles. Like BigjBear said, that is mostly what we have to do with slip yoke t-case, such as the 208 and 241.
    If you are dead set on releaving any undo driveline stress then you would need to get your perches re angled and then get yourself a CV shaft. Pretty expensive though.
    Jesse at Highdriveline sales the shafts for about $325 for the 1/2 ton units and about $385 for the 1 ton unit. But if you have a 208 or 241 then you will have to get a slip yoke eliminator kit, which would be another $325 minus the CK5 10% discount
    Will work for beer, parts and tools.
    90-350TBI-TCI700-241-33"-10/12 bolt w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  16. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    ftn96,
    If you get the CV joint driveline, do you still need to lower xfer case?
  17. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    NO, thats the beauty of it. YOu get to raise the T-case back up to stock position and this in return also takes some angle and binding issues away from the front d-shaft on some of these newer models.
  18. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Good - I am actually getting a quote on a CV dl with the disk emergency brake.
    My shop in Chico works with High Angle in case the Highangle guy is reading - Bent and Twisted.
  19. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    ftn96... or anyone... what does that slip yoke eliminator kit take to install? Anyone done it on a 208?
    1987 Chevy K5 Blazer- 350 TBI
