lowering transfer case
Discussion in 'The Garage' started by sunnyc123abc, Jan 7, 2006.
  1. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    I want to lower my transfercase a bit to reduce vibration. Iv heard of people putting the spacer between frame and the crossmember. Are there any problems resulting with doing this? thanks
  2. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Is that a maybe it wil cure the vibes? Year/make/model/engine/trans required for recommendations. My '85 Burb came with 1" spacers, (I took them out) so spacers are OK, per se. I'm guessing you have 3/8 bolts. If you crank-it taller spacing, might consider making a block that spans both bolts, and probably 2" max. You could also just barely open the holes to fit 7/16 bolts. 7/16 X 20 (machine thread), grade 8, torque to 64-77 ft. lbs. I'd stay with 1" max with 3/8 bolts, even there use 3/8 X 24, grade 8, torque to 40-48 ft. lbs. As you tilt the trans/T-case down, you gotta watch the distributor and fan clearances.:D
  3. fatboy
    fatboy 1/2 ton status
    Jul 1, 2003
    290
    Tennesse
    I use some 2 x 1/4 square tube about 6 inches long and 7/16 bolts without trouble and it took away the vib I had. Go for it
  4. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    There you go, quick and simple. Sharp.:D
  5. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    When I first lifted my 89, I stuck the spacers under the crossmember to kill the vibes, worked perfect. Honestly, it doesn't take but a few minutes to do and if you've got vibes now, why not try it. I had NO problems with mine, drove it like that on the street for about 3 years...
    KP
  6. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    I dropped mine, It cured the vibes and no probs at all since.
  7. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    I dopped mine like 2ins when I first did my lift. after I put in the new trans it's now dropped 3 1/4in if I didn't my drive lines would be horrible. Except I'm pretty maxed out now. My distributor is a pain in the a** to take out because it's almost pinned up against my firewall
  8. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    You will have to watch your front driveline angles with dropping. The farther down you take it the further up you point the front output. Only go as far as you need. Check the angles and try to get the both u-joint on the driveline at the same angle.
  9. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Re; the orig. thread. This assumes the R driveshaft has been checked/balanced?:bow:
  10. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    ok i got two blazers one of themi bought lifted my other is stock my stock one has thiese little spacers after the crossmember inmy lifted the spacers have benn moved up between the crossmember and frame i have no vibes but im soon to get a six inch lift and put my 4 on my other blazer so i hope it dont vibrate still
  11. molokai05
    molokai05 Registered Member
    Dec 14, 2008
    9
    Vacaville,CA
    I just wanted to say that this post helped me out greatly. I put a 4" lift on my 85 K5 and the driveline vibrated a lot. So through searching here I found what I needed. I just used the stock spacers on the bottom of the transfercase crossmember and put them in between the frame and member, test drove and runs like a dream. This is only temporary, I'll be getting some better spacers in place as soon as I find some, probably square tubing. Only took maybe 10 minutes, support with jack, remove bolts, lower slightly to put in spacers and bolts and tighten, that's it. Hope this helps others as well.
    Thanks,
    moli
  12. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    go to local hardware store. and get some bar stock from the small metal rack thay have for simple job stuff. cut to length of cross member and drill holes. then bolt this inplace of the tubes.
  13. Teck
    Teck 1/2 ton status Premium Member GMOTM Winner
    Apr 10, 2009
    2,616
    53
    Mansfield,Tx.
    Would be every easy to make form stock steel and longer bolts.
    Mine was done years ago to help driveline vibration, I think it was a kit rancho made. It is 6 piece of 1/4" to 3/8" thick by 1 1/2" wide by about 6" long, 3 go on each side to lower the transfer case. I used two kits, 5 piece on each side, Never had any problems.
  14. bnate
    bnate 1/2 ton status
    Mar 6, 2004
    138
    San Jose, CA
    Also take a moment to watch your distributor getting close to the firewall. I had to hammer out more room to be sure the flex didn't crack my distributor cap.
    Good luck.
  15. Teck
    Apr 10, 2009
    2,616
    53
    Mansfield,Tx.
    I did have a 3" body lift with that, which did give more clearance.
