Lowering Usable Rpm
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Paxx, Nov 20, 2003.
  1. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    I would like to know what modifications I can make too lower the powerband on my truck. Ok this is what I have under the hood.
    350 cubic inches:(.030" overbore for a total of 355ci )
    Balanced and blueprinted by King Balancing
    Isky Camshaft: 262 supercam(P/N201262): .290 lift, 262° duration, 108° lobe center
    Edelbrock Performer #2101 Intake Manifold
    9:1 compression ratio
    Standard Chevrolet Heads
    Quadrajet 4MV, 750 CFM carburetor
    The engine runs great and produces good power but it makes the power starting at about 2000rpm. I would like to see power starting at 1500 or even possibly 1000 if that's not too difficult.
    What do you guys think? I am thinking headers and exhaust will make a difference but I don't know how much and other than that I have no idea.
    Any help will be greatly valued /forums/images/graemlins/thumb.gif
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    That 108* lobe center hurts....
    I don't remember which, but advancing/retarding the cam is an option....
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I believe retarding the cam is what would be done here.
    Changing cam timing seems to move the power band but not change the numbers at all per DD 2000. Basically, just moves the torque curve down or up, but the shape stays about the same.
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    Swap in a 6.2...
    Rene
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    You need less cam. Didya ever notice that the hp/torque curves that are published by cam manufacturers almost always start at 2000 rpm? Personally, I do a lot of driving between 500 and 2000 rpm and I would really like to see what the effects of a performance cam are in this RPM range. I think that even with a mild performance cam (my Edelbrock Performer is 204/214), you probably lose some torque in the 500 - 1500 rpm range, and with an SM465 (essentially a 3 speed), you need all the torque you can get right off idle.
  6. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    Swap in a 6.2...
    That looks like a post MJ would make. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    but....for low end power it really is the best option
    /forums/images/graemlins/thinking.gif
  7. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    Here are my guesses....
    Smaller valve heads
    Headers with carefully selected diameter and runner lengths
    A "4x4" type cam
    A stroker crank
    More displacement
  8. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    Swap in a 6.2...
    Rene
    I was waiting for you to say that /forums/images/graemlins/rotfl.gif
  9. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    What does this mean? /forums/images/graemlins/confused.gif
  10. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Desktop Dyno 2000, it's a mock-up of a dyno for your computer. You punch in all the specs of your engine and it will spit out a torque and HP curve based on the numbers you give it /forums/images/graemlins/thumb.gif
  11. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Swap in a TBI 454
    What is the duration on that cam at .050"? The cam in my 454 is only like 202* Intake and 210* Exhaust at .050" and like .468" lift Intake anmd .480" exhaust... and my motor pulls the hardest from 1800-3000 RPM..EVEN when I am romping on it, I rarely shift above 4000rpm. So I might spend some time researching cams if I were you...
  12. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    Your cam is not right for low end torque. I also doubt that the lift is only .290. Everything else on the engine seems good for low end. You might get the biggest difference from lower gears.
  13. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    .290" is most likely the lobe lift. Total lift would be multiplied by the rocker ratio, which is 1.5:1 for stock small blocks. Works out to a conservative .435" of lift at the valve. I don't think the cam is all that aggressive...
    Adding 1.6:1 rockers would help a little.
    Rene
  14. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    The 108 lobe center bleeds off to much low RPM pressure in the combustion chamber....
    Look into the Comp Cams 4x4 series of cams. You will want either of the two smaller ones /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  15. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    When I still had the 350 in my truck I had the Comp Cams 260HE which was a great cam for low and mid range...can't recall the lobe center though. I'm sure it was more than 108...and could have been as much as 112.
    Anyways, it did pull pretty good from 1000 rpm and up which is important for anything with a SM465 due to the wide ratio's.
    Rene
  16. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    swap in a 400, I took my foot off the brake and idled over an overpass once while pulling a 4,000lbs trailer. now thats useable low end torque. /forums/images/graemlins/thumb.gif
  17. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    Rene
    This is exactly why I need to lower it. When I shift from 2nd to 3rd unless I shift at 5000rpm I come in below my powerband. I don't like to shift at 5000rpm because I start to lose power at around 44-4500rpm.
    So from the sounds of it nothing short of a new cam is really gonna net me the results I'm looking for? /forums/images/graemlins/frown.gif
  18. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    260HE's have 110* LC's, the 4x4 grinds have 111*....
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    260HE's have 110* LC's, the 4x4 grinds have 112*....
    Mine was 111*.
    Rjfguitar,
    Is a 4,000 lb trailer heavy?
  20. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
