lowest air pressure you have ran
Discussion in 'The Garage' started by VirginiaBulldog, Jul 9, 2003.
  1. VirginiaBulldog
    VirginiaBulldog Registered Member
    Mar 15, 2003
    74
    Virginia Beach, VA
    what's the lowest tire pressure you have ran with 35X12.50 tires on 15x8 rims? This is on my roomate's jeep. TIA
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    cant say ive ever ran those tires on a jeep but i would say..
    if it were my rig i would run 9 in the front 7 in the rear for trails
    i would run 6 in the front 4-5 in the rear on sand....
  3. VirginiaBulldog
    Mar 15, 2003
    74
    Virginia Beach, VA
    no problems with them unseating because of the difference in rim size to tire width. I run 15x10 rims with the same tire on my blazer. What's the rule for rims vs. tires vs. pressure? I have no idea.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    on my 38x13x16in tsl's with 16x6.75in rims i run 24 street 12 on the trail and 4-5 in the sand
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    no beadlocks, i ran 39/18/15 mickeys on 15x14 at 3.5psi. . . .i didn't really know it for awhile because they have such a big surface area it didn't sag that much.
  6. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    I had 35X12.5s on 15X8s on my CJ5. I ran then around 10psi most of the time. Never a had a bead pop off.
    I've ran them down to 8 psi a few times but I got dirt in the bead area once that caused a air leak. That worried me a smidge so that was the last time I ran them at 8psi.
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    nope no beadlocks just stock chevy rims /forums/images/graemlins/thumb.gif
  8. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    depends on the terrain, is my rule of thumb. If you run lower pressure you risk more sidewall dammage (Im sure its not terribly a lot more, but eh...). If the trail your doing has sudden hard changes (jagged rock, or a ledge you might hit at any speed), I'd keep about 15-18 for good measure. If your running only sand, maybe 10-15. It really depends on too many factors, if its really grippy terrain, and you run low pressure, I've seen some people spin the wheels with the tires not moving. I've also seen people air down to about 8 PSI, doing a small hill climb, hit a small rock (4"?) which managed to pinch the tire (tire seemed un-dammaged) but managed to bend the steel rim, enough to leak air. He hammererd it back in and all was good, but... you know, just letting you know low air pressure can have that effect.
  9. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I ran mine that way on my Jimmy with 7 PSI on all 4. the bead ain't going anywhere. I'll be running my 38.5 x 14.5 x 16.5 at the same PSI on the willy's...oh yeah...beadlocks /forums/images/graemlins/thumb.gif
  10. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    With that setup and the lighter jeep, I'd run around 10 pounds. I run that pressure with the heavy Blazer and do fine. I drop to 5 if I need it in snow and stuff. at 4 pounds the tires start to burp air.
  11. VirginiaBulldog
    Mar 15, 2003
    74
    Virginia Beach, VA
    Thanks all. I'll let him know not to worry about it.
  12. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    i run the 33x10.50 tsls on my 150 at about 24psi
