Lowest safe air pressure for 16.5's?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigk, Dec 4, 2001.
  1. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    Lowest safe air pressure for 16.5\'s?
    Anybody got any experience dropping the air in their 16.5 tires really low without popping the bead? What would you say is the lowest you can go?
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
  2. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Re: Lowest safe air pressure for 16.5\'s?
    i've done 12.5 but i'd say that was pushing it, and i never turned hard, and thats before i knew better - doug
    Doug Krebs
  3. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    I run about 15 pounds on the trail in my 38.5x15x16.5's.and have yet to pop a bead,maybe ive been lucky but i believe i will be pushing for beadlocks this next spring so its one less thing i have to worry about.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Before I got the new tires on the K30, which still had the 16.5" Welds with bald BFG tires, one tire had a slow leak and got down to 10 lbs. before I went and aired back up. But this was all city driving, no off roading or what. [​IMG]
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  5. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    what is your rim width?
    I had 38.5/16/16.5 on the recommended 9.75s and they could run flat on the street, never lost a bead
    ran 24psi for daily driving
    found them with nails in them and no reading on the guage lots of times,
    i think that tire size is a special case though, 16" wide on a 10" recommended rim? sounds bizarre
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    I have run 12psi in the sand but I was afraid to go any lower because of all the bad stories I hear. Those were only 33x12.5x16.5 on 16.5x9.75, though.
    <font color=green>Oh man, 4:10's are sure better than 3.08's!</font color=green>
  7. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I regularly run 15-18 on the rocks in mine, never had one come off yet. Granted I drive with a steady foot and don't romp on it when the pressure is that low, but you should be ok with 15 psi or so...I don't go lower than that because it has worked for me, and I don't want to push it...am running 35x12.50x16.5s on 16.5x9.75 wheels...
  8. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    Lowest I've gone is 15 on
    44x19.5 boggers on 16.5 x14 Bart Wheels
    <a target="_blank" href=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </a>
  9. Ryeguy
    Ryeguy 1/2 ton status
    Oct 30, 2000
    Victoria, B.C.
    10, but I'm running Hummer rims. Could go lower with the 44's but really don't see any point behind it.
    --Rob
