Lowest "safe" tire pressure with a bead-locked 16.5" wheel?
Discussion in 'The Garage' started by TruckNutzDude, Apr 2, 2005.
  1. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I'm toying with the idea of adding bead locks to my 12x16.5" wheels, but I want to know a little bit about their advantages. I know I'll be adding some width to the rim, my tires can handle that (44x18 TSL's) Will the single edged bead lock hold the tire on at 5-10 p.s.i. or can I run lower? Is the inside edge of my rim going to hold the tire well with low pressure or should I just start looking for a hummer wheel or those bladder type (tube style) bead locks? My spare tire is only 38" so if I were to lose a bead I'd be in a world of hurt until I got home. Should I just invest in a bigger spare tire? :dunno:
  2. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    if you can't go 5-10 psi with them, Im not sure I see the point of beadlocks... I go below 10 without them, so with'em it shouldn't be a problem. As you said, there is the inner bead... but if I had to guess I'd say it will be fine at 5-10. Getting a bigger spare would be a good idea tho....
    j
  3. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    On my 12" wide rims, the back bead seating area is a great deal larger than the front. I am running weld on beadlocks and plan on dropping mine down to like 3-5 psi for the trails. Same size spare is something required if running a locker of any sort. I ran with a 33" spare when I had 35's, luckily never needed it. Now I have the locker running same size spare just in case.
