LT1/4L60E, 8.5" disk brake 10 bolt, and a 454 FS
Discussion in 'Engine | Tranny | T-case' started by beater_k20, Dec 21, 2005.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i'm gettin the itch to start on my 92, and the deadline i set myself isnt getting any farther away... time to clear out some goodies...
    1994 Caprice LT1 - engine is complete, except for the power steering resivior. i have nearly all of the wiring for the entire car (wasnt sure what i would need for the swap, and what i wouldnt), no ECM. previous owner wrecked the car and began to pull the engine. when i bought it the fuel rail was off of it, so i'm going to assume it needs rebuilt. :dunno: i've also got the 4L60E that was behind it, exhaust manifolds and both cats. it was a local police car, so i know maintnance was kept up on very well for most of that (generally their cars are retired at 110K) SOLD
    $400 OBO
    also have the disk braked 8.5" 10 bolt for the same car. 5 on 5 pattern, same as 1/2 ton 2wd GM trucks. cheap and easy way to get disk brakes! $75 OBO
    1987 454 Chevy, pulled from my buddy's R30 dually. started making a light popping out the carb under load after sitting for a few months, he swapped in another 454. i hit it with a compression gauge and a vac gauge before he pulled it, symptoms are consistent with bad valvesprings. other than the popping, it ran great. block casting # 10069286, head casting # 14081045. complete carb to pan, balancer to flexplate. also have exhaust manifolds, and an acessory drive setup (not 100% sure if its complete). its also got an Edelbrock dual plane intake on it. $500 OBO SOLD
    will consider trades for 3/4 or 1 ton axles, or a 700R4/241 combo.
    hell, its probably a long shot, but i could use a 88-98 K1500 std cab shortbox frame too. All "wanted" parts located
  2. stoneagemaxx
    stoneagemaxx Registered Member
    Oct 30, 2005
    75
    S. Lyon, Mi
    can i get some pictures of both thanks
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    6 months later, BTT
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    nobody wants a big block? :dunno:
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    pics...
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    and the 454
  7. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    any chance of meeting halfway between pittsburgh, pa and you? i need a 454.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i'm currently in correspondence with another member working on a deal. if it falls through, we may be able to work something out.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    sold the engines, got the axles, tranny and frame that i needed. still got the 8.5" disc braked 10 bolt though.
