LT1 Cat vs High Flow
Discussion in 'The Garage' started by Hardcore, Jun 12, 2003.
  1. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    A guy over on another board said that the cat off of an LT1 (I guess Corvette) is a high flow cat and its better flowing then aftermarket High Flow cat. He said they are sheap too.
    Anyone ever hear anything about this, anyone using one??? /forums/images/graemlins/ears.gif
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I saw in a old issue of Hot Rod a test of aftermarket cats. The one that flowed the best was a stock cat from a Tahoe /forums/images/graemlins/shocked.gif
    I don't know about them being cheep...what dealers charge should be illegal!
  3. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    I had an exhaust guru at a shop tell me that there is no such thing as a "high-flow" cat convertor. He says the way to get better flow is to over catilize your vehicle; ie: put a larger convertor on. He also told me that the ones that starting being installed on K5s around 88-89 (not the flat bead style) are what he uses in high performance applications. So if you have that style, maybe the same as the Tahoe one mentioned above, you have the best already if it is not damaged. I had the flat, bead style with 110K miles on it and replaced it with a Catco catilyst style and notice a BIG difference.
  4. dyeager535
    26,975
    One of the Corvette mags did a cat converter swap on a newer Vette not to long ago (can't recall for sure, but LS or LT1 I think) and claimed great results from the aftermarket cat. Dyno tested.
    Of course, IMO, the test was flawed, it was an old used converter vs a new unused, so who really knows. A good aftermarket high flo converter is probably plenty good.
  5. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    Pavement sucks cool website but doesnt have the knowlegde of ck5, but a LT-1 cat has one of the highest flow ratings out of most aftermarket cats
