LT1 heads
Discussion in 'The Garage' started by sled_dog, Dec 4, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'm pretty certain i know the answer but I can't remember ever seeing it in black and white, is it possible to put LT1 heads on a non LT1 motor?
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    if you decide you like reverse-flow cooling....dont you have to put the lt1 flow waterpump on, etc?
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah forgot about that, I think I am going to be looking for an LT1. By the time I put aluminum heads, fuel injection and some other stuff on my motor for all to work I could probably find an LT1 for about the same price and have a better fuel injection system.
  5. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    The old LT1 heads from a 71 Camaro are just sbc heads and need no modification or special parts but I would have to take some one elses word on the new lt1 heads as I don't know.
  6. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    It is by no means a bolt-on deal. Substantial machining is required to make this work. There are no coolant passages to the front of the intake like all other small block motors.
  7. Confedneck
    Nov 1, 2002
    5,236
    the "old style" was LT-1..new style is LT1 and will not be a direct installation..
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    They are definately not a bolt-on and go deal. There was an article a while back I read that gave info about a tech at a Chevy dealer that got them to work on non-LT1 blocks. There was a lot of filling, drilling and machining though....
    Heres the article:
    http://www.lt1intake.com/LT1_retrofit.htm
  9. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Might want to do some searches here and on www.thirdgen.org about the Opti-Spark system and the effects of WATER and MUD on said system............ /forums/images/graemlins/shocked.gif
  10. Confedneck
    Nov 1, 2002
    5,236
    convert from optispark to the ls1 COP setup for 700 or so, or go "dynaspark" which is the optispark replacement which is "the last optispark you'll ever buy"
