LT1 in a Blazer???
Discussion in 'The Garage' started by k5-newbie, Apr 9, 2006.
  1. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    ran across an LT1 with a LT4 intake and cam.... was wondering if it would be a good idea to put it in a Blazer that sees mostly rock crawling and trail rides...but of course some of the trails have water crossings. I know the opti spark is in a less than desirable spot for water. Also, can i use my turbo 400 with the LT1?
    thanks
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you could use your 400 with it, the belhousing pattern is the same as all v8 chevys
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    optispark is undesirable on the street let alone trails. Its not just water crossings, dirt, mud, dust, all that crap can effect the optical pickup. If you can get the engine for a really good deal, I'd say give it a try, when you have trouble, convert to a different style of distributor. They make better setups they just aren't cheap.
    Also does it have LT4 heads? LT4 intake does about nothing for performance without LT4 heads as well. LT4s have taller intake runners. If it is just an LT4 intake on LT1 heads it could actually be hurting performance. Not sure if it is even possible to raise the ports of the LT1 to match the LT4 intake. Stock or Hot LT4 camshaft? Big difference.
  4. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    Thanks for the help guys...I will find out more about the motor tonight...and yes, it is a GOOD deal, motor, computer, wiring harness, everything but starter, for next to nothing:eek1: . It is a buddy of mine who was gonna put it in his 87 Firebird, but instead just purchased a '02 Vette.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    quite a difference, but a good one, from 3rd gen Firebird with 2nd Gen Small Block power, to 5th gen Vette with 3rd gen Small Block :wink1:
