LT1 intake on a 91?
Discussion in 'The Garage' started by garlicbreath, Apr 24, 2005.
  1. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Hey, does anyone know if the intake setup from an LT1, like the caprice cop cars will bolt onto a 91 motor? I am looking into injecting my blazer, but the TPI setups are still pricey.
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    Yes, it can be done, and is actually an extremely good intake to replace the stock TPI intake.
    You can find more information about what kinds of machining / changes need to be made to bolt the intake on at this website:
    www.lt1intake.com
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    actually its not a great replacement for us. I wanted to do it but its pointless on a truck. The LT1 is great for Camaros and Firebirds. It is good for a large camshaft with high RPM power. For torque the TPI intake is far better.
    http://www.popularhotrodding.com/enginemasters/articles/hardcore/0803phr_beast/
    Oh and both the links that are posted are just replacing a TPI intake with an LT1 intake. I'm in the market for a TPI setup, they don't seem to run much more than $500. Not much when you compare to aftermarket.
  4. garlicbreath
    May 17, 2003
    1,136
    Denver
    One of the reasons I am considering the LT1 also is I have sportsman II heads, headers, 10-1 compression, and zz4 cam. If I understand right a stock TPI setup would choke my motor.
  5. garlicbreath
    May 17, 2003
    1,136
    Denver
    Well, apparently the LT1 intake doesn't work with sportman heads! Thanks though.
  6. camarossguy2
    camarossguy2 1/2 ton status
    Aug 10, 2004
    214
    ABQ NM
    Also, the lt1 intake do not have a distributor hole in the back...you would need LTCC LS1 coil packs, or an opti-spark conversion
