Lube Job
Discussion in 'The Garage' started by bigred85, Nov 12, 2004.
  1. bigred85
    bigred85 Registered Member
    Jul 12, 2004
    61
    Dallas, TX
    I was wondering if anybody had a diagram of all of the Lube points on my 85 k5, especially all of the steering stuff.
    Thanks in advance.
  2. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    I don't know if there's a diagram or not. All I can say is that every pivot point should have one (not counting the pitman arm).
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    or the upper ball joint
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Every tie rod, bushing (if their greasable) and u-joint. You've got at least 6, if not 8 or 10 u-joints to grease.(depending on your driveshafts and what not).
    While your at it, repack those bearings!
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The upper ball joint usually can be greased, you just have to remove the plug, grease it, and put the plug back in, which is tricky to do with the axle shaft in the way.
  6. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I've always just stuck a needle in. Bad idea?
