lubing speedo cable?
Discussion in 'The Garage' started by xpndbl3, Oct 12, 2006.
  1. xpndbl3
    xpndbl3 1/2 ton status
    Jul 30, 2005
    510
    orland park, IL
    my speedo cable makes a loud screeching noise that "bounces" up and down as I drive for the first 15 minutes or so now in colder weather. I'm assuming I have to lube the speedo cable from what I read online. Doest this mean pulling out the dash pad and guage cluster? Also what lube can I use to quiet it down and make it much less bouncy?
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yeah you have to pull the cable off the speedo. Usually requires pulling the guage cluster. To lube it use graphite or vasolene. Some other types of greases/oils can damage the spedo head, cable, or the plastic drive gear. They sell spedo cable lube at many auto parts stores. But its just a little tube of graphite
  3. xpndbl3
    Jul 30, 2005
    510
    orland park, IL
    would white lithium grease work the same?
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    The problem with greases is that they collect dust and roll it into a ball. Kinda bad. Also, with the way the speedo cable is wound, anything thick that you put on it will get pumped into the speedo head. If you remove the inner part of the cable and clean it and clean the inside of the tube, it will help alot. You can soak the inner cable in penetrant for a longer lastin effect, and the penetrant is a thin oil. You can also use graphite, just not both at the same time.
    FWIW........ I have used axle grease before with no ill effects.(:doah: just dont tell anyone:doah: )
