Lug Nut Torque
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Laurie, Jun 25, 2000.
  1. Laurie
    Laurie Registered Member
    Jun 3, 2000
    44
    Oregon
    Ok, this is my lug nut problem continued. I did find nuts that were wide enough to compensate for the wear and tear on my wheels - yeehaw, don't have to replace wheels yet! But, my owners manual makes a big deal out of lug nut torque. I can't believe that everyone who changes a tire runs to the shop to have the nuts torqued. Do you dp that??? In fact I think that this is part of the problem - They were put on so tight that the nuts ate away at the wheel holes. Am I way off track???
  2. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    I'd say 100 ft lbs is a good torque for a truck. It mite be more if you have big tires, but I'm not sure on that.
    J.D.
    88 Gmc Jimmy
  3. okie
    okie Registered Member
    Jun 23, 2000
    23
    mcalester, oklahoma
    lug nut torque is more important on aluminum wheels then it is steel wheels, just try to tighten evenly, 100-110 sounds about right, but i can't lie, i allways use an impact
  4. bigjbear
    Feb 18, 2000
    13,973
    454
    Marietta GA
    Everything I have ever read says 100-110 ft.lbs. If I have the time I use a touque wrench on the truck. On the Jeep I always do, it has aluminum rims. Its not that big of a deal with steel rims. Jim
    BigJBear '80 GMC
  5. Laurie
    Jun 3, 2000
    44
    Oregon
    Thanks all. Looks like I need a torque wrench. Can't stand thought of paying someone to do this :)
  6. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    I've never seen any problems tightening except on newer cars with steel wheels. If you don't torque them evenly they can warp the rotors b/c they are not as thick as cars say 20 years or more old. Your truck rims are plenty thick either case alum and steel. and your rotors are plenty big. I never torque mine on any car and haven't had a problem. I do use an impact most of the time. I can't say you wouldn't have problems, just keep them tight enough to stay on there.
    Wasn't me.............
  7. Udy
    Udy Registered Member
    Apr 2, 2000
    79
    fairport NY
    I would definitelly torque aluminum wheels! The place that did my gears installed the rims with an impact. I almost lost a wheel when one stud snapped going down the road. The others vibrated loose due to the uneven-ness. Also, recheck the torque after a few miles!
