Lug Nuts backing out.
Discussion in 'The Garage' started by BizeeB65, Feb 6, 2006.
  1. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    Ok gents, please post your input on how to remedy this problem. I was on my way home from wheeling yesterday, and all of a sudden BAM, I'm on three wheels and the 4th (pass. front) is chasing me down the road. shortversion = I need to know if I would be better off replacing the studs on both front hubs (D44 6 lug) or risk putting new lug nuts on the less-than-reliable studs? I had purchased new lug nuts for all 4 wheels, and didnt replace the ones on the wheel that fell off (time/space crunch). Give me your suggestions. I am pretty sure I have to replace the hub/rotor I was riding on, since it ground off some of the outer ring slowing down. I have considered getting a trailer to haul my rig with too, to prevent these sort of things from happening. Plus the ride is much nicer in my Tahoe, and I would be able to go to some of the long-distance events! :D
  2. BizeeB65
    Oct 12, 2005
    859
    Louisville, KY
    anyone feel free to chime in.
  3. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    What kind of rims are you running, and what backspace? I have never had this problem.
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Lock wire
  5. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    Ditch the studs..
    I'd replace the studs if they were damaged even slightly..your life is riding on them,and the road is a deadly enough place as it is,without the added risk of your wheels passing you!..also,the rims might need to be junked too,if the holes got egged out..NO lugs will stay tight on a damaged rim,no matter how "new"....
    Also,some cheap steel rims are not "coined" where the lug nuts seat,they are just flat stamped steel,with countersunk holes....lugs constantly loosen up on rims like that,I had a set of chrome spoked ones that I had to tighten the lugs DAILY when I drove 150 each day to work and back..:eek1: ..
    I torched the centers out so no one else would be tempted to use them again..I almost got killed when one came off the right rear at 65 mph!..and it caught up with me after I stopped,and rammed itself under my truck so hard it lifted it off the ground,bent the bumper to hell,and blew the tire's sidewall right out(GASH!)..even bent the rim,and my rearmost crossmember!..
    Yeah,I'd change all the studs,check the rims over good,and get new lug nuts too...cheaper than a casket and funeral..:crazy:
  6. brotha b
    brotha b Registered Member
    Nov 4, 2005
    31
    vernal, Ut
    take that 6 lug out and get an 8 ,60s are best but 8 lug 44s are good
  7. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    I had it happen to me twice. the first time it was Sam's Club's fault (stupid tire jockeys) the second time (different wheel) they had loosened on me. I replaced just the lugs and nuts, haven't had another problem with that wheel. I'd replace them and be done.
  8. BizeeB65
    Oct 12, 2005
    859
    Louisville, KY
    My wheels have the deep hole in em that requires a long lug and washer to seat them. It is a PITA to take the wheels on and off, which is already reason to ditch them. I dont think the holes are egged out now, but I didnt have time to examine them after it happened. I would love to get an 8 lug axle front and rear, but being a full time employee/student/dad leaves little money for that swap right now. Anyone got some 15" 6 lug rims they wanna get rid of?
  9. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    I have had this happen to me twice on one of my k5's. Both times they were aluminum wheels.
    The best thing you can do is replace the studs and the lug nuts. At the bare minimum replace all the lug nuts. The threads in the nuts are cut, not rolled,and are therefore softer than the stud threads. Because of this, it is usually the threads on the lug nuts that "strectch" (yield actually).
    If you have aluminum wheels make sure to re-torque the nuts after about 25 miles or so.
    Also, look up the torqe specs for your lug nuts and use a torque wrench. Many people over-torque the lugs, which damages the threads.
  10. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah studs aren't that expensive when you compare the cost of repair after losin a wheel. studs on halfton running gear get torqued to 100 ftlb for these years of trucks.
  11. goldwing2000
    goldwing2000 Guest
    Uhhh... no they don't. The torque spec for 7/16" studs is 85 ft-lbs.
    100 ft-lbs is the spec for 88-up IFS trucks because they went to a metric 12mm stud.
  12. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    interesting. i suppose we over-torque chevy trucks at work.
    and we never torque 88+ with anything less than 120...most are 140 on up even through the brand new gm fullsize trucks.
  13. goldwing2000
    goldwing2000 Guest
    Don't take my word for it. Look it up in the service manual. I'll gladly admit I'm wrong if the book says otherwise.
  14. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    I had this problem on my 79 rig. Was pissing me off, I thought someone was out to get me and loosening my lugs while I was sleeping. Anyway, I found the problem was due to the wheel bearing having some slop and making vibrations. I replaced the wheel bearings and studs on the messed up hub and no longer had the problem. if I were you thoug, I would deffinately NOT run the studs that the lugs backed off of.
    ~Brian
  15. broke73
    broke73 1/2 ton status
    Apr 12, 2005
    109
    Grand Blanc, MI
    A little blue loctite wouldn't hurt.
  16. BizeeB65
    Oct 12, 2005
    859
    Louisville, KY
    No way I'm putting loctite on my lugs, not unless you wanna come over and take em off when I need to work on it. :D Nice first post NOOB!
  17. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    haha, had it happen to me as well with 6 lug aluminum rims, not as extreme as ur story, but i kept hearing banging noises and it was the rear rim banging against the studs, took me a couple days to figure it out and when i did they were almost all off....that woulda been rear ugly
  18. broke73
    Apr 12, 2005
    109
    Grand Blanc, MI
  19. BizeeB65
    Oct 12, 2005
    859
    Louisville, KY
    Ok, info taken, but arent lugs designed so that you dont have to add anything to them for them stay on?
  20. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    yes, working at a tire shop, ive never encountered a car that required us to add a sealant or thread locking substance when reinstalling the wheels.
    if anything, occasionally we add antisieze. proper torquing with proper hardware should keep them tight.
