Lug pattern Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerWheels, Mar 11, 2003.
  1. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    Is the stock 6 lug pattern the same as a stock 4x4 Toyota?? I found a steel wheel pacer made for Toyota's and I seem to recall them having the same pattern. Could someone verify this or correct me? Thanks
  2. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    I believe they are the same. The stock 6 lug pattern on ours is 6 on 5.5".
  3. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    i belive the only problem you will have is one of the two center hole is bigger. so if stock rims you might only be able to go one way. i think the gm hubs are bigger. so toyota might take some grinding to make them fit.
    /forums/images/graemlins/confused.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes the pattern is the same. Just make sure the center hole is big enough.
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Toyota hubs and center holes are bigger than GM. Both are 6 on 5 1/2". What you are looking at should work.
  6. wa_jeeper
    wa_jeeper Registered Member
    Mar 3, 2003
    85
    Great Lakes, IL
    Yep, they'll work. Anything that fits a 6-lug Toyota will fit a 6-lug GM but not vice-versa. Toyota hubs are about 1/8 bigger all the way round.
  7. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
