lugnuts- right and wrong way?
Discussion in 'The Garage' started by TXsizeK5, Mar 22, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    This guy told me that my lugnuts were on wrong... that the pointed side should be touching the wheel... is this right? or is he full of it? Cause i had a reputable shop put my axles/tires/wheels on and im sure thye wouldnt overlook something like that... (?)
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have always been told and used the pointed side in. It is the way I have always seen them and used them. The point starts to go into the lug hole and centers everything up I assume.
    Also, the lug nuts I use now are the acorn style, and they have a point built into them, and they only go on one way so the point goes in.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Yup. The beveled end should point towards the wheel. This keeps the rim in the proper position and also stops the rim from riding on the wheel studs.
    Unless maybe both ends of your lug nuts are beveled..... /forums/images/graemlins/confused.gif
  4. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    yeah the tappored in goes towords the wheels. This centers them and tightens them up. If you look at the accorn style they have tappored ends too.
  5. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    doh you beat me /forums/images/graemlins/blush.gif
  6. BowtieGuy3
    BowtieGuy3 Guest
    Whichever end of the lug has the taper on it.....thats the end that goes towards the wheel. If you have open lugs, and both ends are tapered, then go with whatever end looks like a 45 degree bevel.
  7. Can Can
    15,552
    136
    Yeah, thanks to my cat-like reflexes...... /forums/images/graemlins/wink.gif /forums/images/graemlins/rotfl.gif
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I beat you both though. /forums/images/graemlins/grin.gif
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i've got the super cheap open lug nuts from Autozone /forums/images/graemlins/grin.gif
    when i put them on i was kind of mad i had switched to a 14FF. . .now i have 8 LUGS TO LINE UP!!!
