M1008: How much tire with no lift?
Discussion in 'The Garage' started by Mastiff, Jan 11, 2006.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I swear there was a thread about this, but I can't find it... anyway, anyone know how much tire you can get under a stock M1008, no lift? It sits pretty high, so I'm thinking 33's at least would fit no problem. If anyone had pics with bigger, that'd be great.
    Also, is it realistic to get something like 35" tires, keep the E load rating, and have somewhat aggressive tread still? Hmm. I guess Humvees have 35" tires and those things are like 2 ton or something. :thinking:
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    Humvees have 37's. depends on which tire you go with, BFG 35's are actually 34", ive seen those under stock height trucks. dont think 35" swampers would fit w/o trimming
  3. 85-m1028
    85-m1028 1/2 ton status
    Apr 26, 2005
    485
    costa mesa california
    I've got 35" x-terains on mine with a little trimming and massage
    no rubbing at all even at full stuff and full lock
  4. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Have any pics you could put up?
  5. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Some humvee's had 36's too. It will also depend on your wheel choice.
  6. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I'd plan on sticking with my stock CUCV wheels, which are 16".
  7. 85-m1028
    Apr 26, 2005
    485
    Mastif: go to steelsoldiers.com and look in the photo gallery under 85-m1028, I have since painted it but the tire pic in there. if you're going with the stock rims a 10" wide tire may be max with out rubbing at the factory offset, which will limit your selection. I am running 17"x9" steels with 35" x12.5 xterains, 4.56 gears and 3sp auto + diesel not great on the open road even with 35's should have gone with a built 700r4 instead of rebuilding the 400:doah:
  8. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Cool, thanks. Looks good, and like there's decent room still. So little articulation with the 1.25 ton suspension that you don't have to worry about too much "stuff". :wink1:
  9. 85-m1028
    Apr 26, 2005
    485
    I put some es9000 shocks on the front set for 0-2" lift and a big old 5/8" shaft so the shock being a little taller is now the limiting factor for uptravel but allows for a little more droop, but my factory springs are shot, I got death wobbles 3 times on my way home today so I will be looking at a new set of springs a.s.a.p. not really sure which ones work well for the 6.2 "weight wise"
  10. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    one guy on here says he got 38" michelin military tires on his army pickup with no trimming.
    i'd like to that "some day".
  11. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    You think your factory springs are shot or something? I use my truck to haul stuff, so if I ever replace the springs I'll want to keep the 1-ton rating, even though it's not best for offroad stuff. Something to keep in mind I guess.
    Doesn't national Spring make lots of custom springs? I wonder if you could just ask them for factory (or 1-2"? lift) springs for a 1-ton K30 with diesel.
  12. 85-m1028
    Apr 26, 2005
    485
    well the combination of taller tires and the heavy offset of the rims could also be contributing factors, my springs are inverted and the bushings are shot too just needs to be gone through. It does it randomly, its a combination of bump, hop while the brakes are applied and BAM death wobbles!! It make a big difference when there is a load in the back, it rides like a caddilac!! Deaver Spring Co. isn't far from me I might see what they have, could get expensive!!
