m1008 w/ a diesel - What gears in those axles?
Discussion in 'The Garage' started by TopOff, May 29, 2003.
  1. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I keep thinking it will be 4.56s in the Dana 60 and 14 bolt. But then with stock tires and a diesel that redlines at 3K RPM it will have a max speed of 55 mph.
    SOOO
    What gears did this M1008 come with?
    Also what tranny and x-case would an 85 M1008 (Diesel) and a 94 M1008 come with?
    Thanks in advance.
  2. bigjbear
    Feb 18, 2000
    13,973
    454
    Marietta GA
    M1008s come w/4.56s. There are no '94 M1008s. Most M1008s came TH400/NP208, some had TH400/NP205.
  3. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    The m1008 will have 4.56 gears, detroit in the rear & MIGHT have a trac lock up frt but doubtfull.
    Trans will be a 400 & t-case will be a 208.
    Very few came with the 400/205 setups.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Once again, 4.56 is the only option...
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Mine came with 400/205. I don't think 1008s ever came with front trac-loc unless swapped in by the pool. IIRC, they were spec'd only in the 1030s? Ambulance/Radio trucks I think? Whatever... Point being, I don't think they existed in the 1008 whatever the other designations were...
  6. bigjbear
    Feb 18, 2000
    13,973
    454
    Marietta GA
    I have not taken the time to look it up, but that is the same info (all M1008s were open in the front, only radio/ambulance trucks had the L/S in the D60) I have seen repeated and never seen the BS flag go up.
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Yep, 4.56 gears.
    With those gears, no overdrive, and stock tires it will not be a very good truck for cruising the highway. My truck with 4.10's and 35's would cruise okay at 65 mph in Drive (shifted out of OD) but the engine was revving pretty good. Now with 38's and with the 4.10's the engine runs at a pretty good rpm at 65-70 in Drive.
  8. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    KEWL THANKS everyone.
    Was there ever a 3/4 ton M1008?
  9. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    if you have a th400/205 its a M1028A1, have you ever pulled your front cover? You should have a front trac lock, if it has the 205.
    Cheers, rugger
  10. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    No 3/4 CUCV's just 1 tons(technically they're rated at 1 1/4 ton but they're the same thing as a K30).
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Nope, open D60 front, now locked. Guy I got it from got it from "said" he got it from the auction just as it came to me, and that it was a 1008. <shrug> Who knows what happens in the motor pool... I was just happy it WAS a 205. /forums/images/graemlins/laugh.gif
  12. rugger03
    May 14, 2000
    829
    around
    well can't win them all.
