m1009 military blazer rear axle?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BINDERMAN, Feb 17, 2003.
  1. BINDERMAN
    BINDERMAN Registered Member
    May 13, 2002
    18
    BIG STATE OF TEXAS
    I am going to look at a really cheap cucv/m1009 military blazer (1986). Problem is if I buy it it has no rear axle. My question is what is the width between the axle spring perches if measuring from spring centering bolt holes in perches? Would take one of my pickup rear axles to put under it to ease the loading process onto my trailer if it will bolt up temporarily. Thanks for any info!!!
  2. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    if you are taking an axle from a 1/2 or 3/4 ton will bolt up just fine, same spacing, FYI, it came with a 10 bolt with 3.08 gears stock /forums/images/graemlins/thumb.gif
  3. BINDERMAN
    May 13, 2002
    18
    BIG STATE OF TEXAS
    Thanks for the answer and a little info to boot. Was curious about the gear ratio to. Thanks again.
  4. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    Hey Chuck
    Where are you in Texas ?
