M1028 question
Discussion in 'The Garage' started by MudFrog, Feb 3, 2005.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Did all M1028's come with Dana 60 / 14 bolts?
  2. goldwing2000
    goldwing2000 Guest
    No, but I hear the M1008 does. :D
    M1028 is a 120mm anti-personnel canister cartridge designed to be fired from the main cannon of the M1A1/A2 Abrams main battle tank.
  3. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Really... hmm...
    Was at a site and they had 6 M1008's for sale and 5 M1028's for sale, all were different trucks and both listed as 1.25 ton
    Thanks for clearing it up.
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
  5. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    The M1028 I believe are the 1.25 ton ambulance with the dana 60 front & trac-loc & 14ff detroit locker both filled with 4.56 gears.
  6. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    So if I find one claiming to be a M1028 but has a regular pickup bed do you think it really is an M1028? I would really like to get a Dana 60 with a trac-loc.
  7. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    m1028
    My M1028 has a 60 and a 14 bolt.
    Mike
  8. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Does your Dana60 have a Trac-Loc.
  9. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Ever since the day i talked to ya, i wish you were closer.Good luck with your project, Jacob
  10. goldwing2000
    goldwing2000 Guest
    Silly military. They use the same designation for lots of stuff.
    An M1 is two different kinds of rifles, a battle tank, a gas mask, etc, etc...
    Good to know the M1028 is a truck, though. It'll help me broaden my search.
  11. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I hear trac-loks aren't worth much in terms of performance. I have one in my D60 but I haven't put it under my truck yet so I can't evaluate it. Rumor has it that one member took out the rear driveshaft, locked in one front hub, and put it in 4wd and the trac-lok couldn't pull the truck forward on level ground. Just my .02
  12. prerunner1982
    prerunner1982 1/2 ton status
    Nov 4, 2002
    235
    Oklahoma
    first off... a CUCV ambulance.. is a M1010.
    2ndly... the m1028 came in 4 versions.
    the m1028 is a SRW version and it had the np208 tcase.
    the m1028a1 is a SRW version that had a np205.
    the m1028a2 is DRW version of the a1.
    the m1028a3 is a DRW version with a np208.
  13. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    This one is the SRW version, but not sure if it has the 208 or 205..
