Mabye dumb ?---?'s about double shear and crossover with heims
Discussion in 'The Garage' started by SCOOBYDANNN, Dec 30, 2006.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I am going to start a fullwidth project on my roomates Scout and want to get all my ducks in a row
    I am looking at this kit to "keep it simple"
    Can you tell me what is missing.
    well I'll tell you---Where does the tie rod go? There is only one hole in each of the arms and there is no "factory" location.
    One of my ?'s is.
    Is I considered "double shear" if you have the draglink on the top of the passanger side arm with a bolt going through the top and the tierod going to the bottom using the same bolt?
    And if not. how would you make (at least) the draglink side in double.
  2. Txchevy18
    Txchevy18 1/2 ton status
    Aug 29, 2006
    225
    Tx
    OK im going to try and answer this one the best I can.
    The tie rod goes above and in front of the axle housing instead of down and directly in front of the diff cover where it would go factory. It seems that teh factory position was shaved of or wasnt cast on to the knuckles. The draglink should connect to the steering arm on the passenger side knuckle in the most forward hole. Though it may vary due to clearances.
    Yes a soild bolt through a hiem and the x-over arm is considered double shear.
    Hope that helps good luck w/ the project. :laugh:
    Txchevy18
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I'd skip on the SRE's and use TRE's. PartsMike should be able to supply those parts as well.
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    I'm not sure I understand what you are saying, but I don't think what you are describing is double shear. This is what a double shear steering arm looks like:
  5. Txchevy18
    Aug 29, 2006
    225
    Tx
    YA your right I was thinking of a link mount and not ateering arm. Sry about that. Good call 383.
  6. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    that is what I understood as double sheer---now how can I make a standard arm into double sheer---is it even possible?
  7. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    not unless you weld onto the steering arm a piece that would sandwich the heim joint.
  8. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Um, double shear makes no distinction btwn whether there is a single SRE and two tabs or a single 'tab' and two SRE's.
    The problem is what the direction is of each part's force. Suppose a single steering arm and 2 SRE's. One on the Draglink and the other on the tierod, with the steering arm sandwiched btwn them.
    The force direction of the tierod SRE is in the same direction as that of the steering arm when turning. Those two forces are not on either side of the draglink SRE (whose force is in the opposite direction), so the bolt is still being twisted.
    For it to work out correctly the draglink SRE would be against the steering arm and have the tierod SRE stacked against it. Not very practical to do.
  9. Txchevy18
    Aug 29, 2006
    225
    Tx
    I dont mean to sound dumb here but what is a SRE?
    Thanx
  10. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Spherical rod end
  11. DesertDueler2
    DesertDueler2 1/2 ton status
    Dec 25, 2004
    132
    Chandler, AZ
    Hey Dam, dont wean to hijack, but checking to see if you have talked to your friend on those axles?
    Dan
  12. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    I'm bumping this thread back up... because I have some questions...
    a) 383... who made that arm?
    b) Assuming you knew how to weld, is there any reason at all that you couldn't just add a piece of steel on top of a normal steering arm that would make the thing double sheer? Seems like if it was beefy enough and uber-welded (Tig?) that it'd be a hell of a lot stronger than the single sheer set ups that seem common.
    I am going to go full hydro... and would prefer double sheer. Doesn't seem like many people do it tho. Even on pirate, where there is all kinds of peeps with hydro...
    :thinking:
    j
  13. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    This is what I figured I was going to do, but, in the end I ended up just using DLE's instead of heims---If I ever cross this bridge again that is what I will do.
  14. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    b) That depends on the shape of the piece added. If it's just a piece of strap bent 90* & stuck on there, then no.
    If it is integrated into the steering arm so that it can take 1/2 the steering load on that knuckle then certainly.
  15. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    c'mon now... even redneck engineering deserves more credit than that. :thumb: :)
    j
  16. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    I only mentioned it b/c I've seen it done.
  17. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    scary! If I did mod an arm to be double shear it would probably look something like the end of a yota raised steering arm (the ones that go up at an angle and then are flat again where the tie rod attaches) welded to the top of an existing arm just past the studs that attach to the knuckle.
    speaking of knuckles... I need to get some bling ones. 44s + full hydro = old stock knuckles = ka-boom!
    j
