Machine shop in Phoenix...
Discussion in 'Rocky Mountain Region' started by K5Glazier, Dec 13, 2006.
  1. K5Glazier
    K5Glazier 1/2 ton status
    May 29, 2003
    220
    Chandler, Az.
    Anyone know of a machine shop that will bore out a GM throttle body?
    Need to get a 350 TB bored to a 454 TB.
    Thanks,
    Joe
  2. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    I'm pretty sure you can't bore out a 350 TB that much. The size difference is too great. You'd go through the wall. Stock bore size on a 350 TB unit is 1 11/16" and bored most are 1 13/16". Stock 454 TB is 2" and bored are 2 1/16". Check out turbocity.com, cfm-tech.com, and there's also a guy on ebay who's substantially cheaper who does them (i'm not vouching for him though). IIRC the guy on ebay sells 454 TBs without a core return neccesary, so you might want to check that out.
  3. K5Glazier
    May 29, 2003
    220
    Chandler, Az.
    Thanks for the info. Have to check on that.
    I do have the 454 tb, but does not have provisions for the tv cable (700r trans) and harness connections are different. Hmm, guess I,ll have to investigate a little further.
    Joe
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The harness can easily be rewired, I think the pins will just switch to the new housing IIRC. Not sure on the TV cable, is it 75 ohm coax? ;)
  5. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Ummm... So does anyone know of a good machine shop? I may consider doing a little motor work if I can find a decent one. At any rate, it's nice to have a place to go if you need to. Thanks...
