Machining 454 BBC and crank, how much $$$ to expect?
Discussion in 'The Garage' started by fortcollinsram, Dec 4, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I am going to be taking my 454 blck and crank in to a to get machined...how much can I expect a good machinist to charge to freshen up the block...I don't even think it needs bored over but I don't have the tools to measure if it really does...So worst case, it needs bored over .030", decked, and the main bearnings saddles need aligned bored/honed...How much $$$ are we talking...I had the same guy rebuild my heads and it was a titch over $300...that was to get them milled .010", valve job, new guides and seals, reground valves or replaced them... I just wan a general estimate to what it mght cost...
    Thaks
    Chris
  2. motorheadnelson
    motorheadnelson Registered Member
    Aug 12, 2001
    80
    Fort Mohave AZ
    Just for reference, I did this stuff this spring..Block prep(cook, magnaflux,brush oil gallery, seal/install new oil and cam plugs, install cam bearings,install ARP main studs,I supplied),110.00...Bore & hone .030 using torque plate,96.00...Parallel block (four corner deck),.020,145.00...Line hone, 80.00...Resize rods,88.00...Install ARP wavelocs(I supplied),15.00...Pressfit pistons,24.00...Turn crank,80.00...balance assembly,125.00...bead blast rods,20.00. /forums/images/graemlins/deal.gif
  3. motorheadnelson
    Aug 12, 2001
    80
    Fort Mohave AZ
    Pretty par on the head work. Had head rebuild(guides,seals,surface,magnaflux) plus bull hog for 2.19/1.88 valves, 3 angle grind, set spring pressure, for a paltry sum of 524.00. We must love these things. Plus at home I blended, relieved, port matched intakes, and cc'd chambers. Bunch of hours and beer. /forums/images/graemlins/thumb.gif
  4. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    That sounds good...I am going to have them do what ever it needs...I am getting new connecting rods and pistons so I only have to pay for the wrist pin installation on those...one more question, wat are the chances that my crank will need to be reground...all the journals are in good shpe and you can hardly feel any ridges with your fingernail when you scrape your finger in the axial direction...do you think that will be able to be polished out? Thanks again..
    Chris
  5. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Look in your phone book for address of a place called ADC Machine (970-482-1927) ask for Charlie. This guy is awesome!!!!!! He does most of my stuff. He does all the work for a speed shop here in town caled "Outlaw Performance". HIGHLY RECOMMEND Tell him "The guy (Don Nath) from Outlaw Performance" sent you. /forums/images/graemlins/deal.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/deal.gif
