machining an np205
Discussion in 'The Garage' started by muddyblzr, Jan 12, 2006.
  1. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    from what i hear when you go from a 10 spline input to a 32 spline input you have to machine the case to fit. what all is needed to be done? i found a 10 spline 205 pretty cheap and i was just gonna swap in the 32 spline input for my doubler
    anyone have any knowledge to share on this?
  2. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I may be able to help....
    I know of a different bearing and spacers that you can use and not have to machine.... if you are using an ORD Doubler adapter.
    Marv
  3. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    use the large style th400 bearing... give 40 bucks or less to your favorite machinist.. tell him to size it to a slight press fit
    bam... have a late model case....
    ORD talked me thru this... it was easy
    cam
  4. muddyblzr
    Nov 2, 2004
    623
    alright sounds good. im gonna be going with a wms adapter so i can have the 203 upside down. i know a few machinist maybe a good lunch and some beer will cover it. does anyone have the specs on this bearing?
    what exactly do they use to machine it out?
  5. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    best thing to do is to actually get the bearing and give it to the machinist so they get it right the first time.
    j
  6. muddyblzr
    Nov 2, 2004
    623
    after i posted i thought about that and i agree. when i get the t-case ill be picking up a bearing as well. anyone got a part number on this. ill head down to o'reilly now and see what they got for me
  7. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    nope, sorry. AFAIK its the same bearing as they use on all the married Ford cases (31-spline) though, if you need to look it up in a parts catalog or something. I'm gonna get a full rebuild kit for my 205 when I get it machined so I've never looked for a part number for just the input bearing. NWF or ORD could prolly help.
    j
  8. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    This is very true since there is no second time if the hole is made too large. :deal:
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Numero Uno needs to get me some part numbers :D
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Once machined (or using Marv's bearing) you can also use the Ford 31 and save some dough if you don't want to fork out for the relatively rare 32 spline GM input. Same thing, same size, same length, just one less spline. But make sure you tell them when you order the adapter. This is what I run.
  11. muddyblzr
    Nov 2, 2004
    623
    my friend has a some t-cases he said i could pick through for the 32 spline stuff and the inputs. if i cant get a 31 or 32 spline input out of there ill just fork over the extra dough for the short 32 spline nwf sells. its 125$ i believe
  12. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    alternatively, NWF has used 31-spline ford inputs. They couldn't be toooo expensive, if I remember right for awhile there Kyle was including them with doublers for free if ya needed one.
    j
  13. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I have a ford 205 I picked up for $100. Has 32 spline outputs, fixed rear yoke and a 31 spline input. You can get all three shafts for cheap like I did, 2 out puts and one input.
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    That's exactly what I have. Ford 32 spline outputs with 1410 yokes, 31 input, and a GM twin-sticked case.
  15. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    Factory bore for the "big" bearing is 3.550, the bearing measures 3.543. Yep it's that sloppy! I have done about four of these 205 upgrades and I have had the best luck with 3.548.
    I was taught over the phone/internet by Kyle from NWFW, he is a great guy and will help any way he can!
    Jeff
