Machining dually hubs
Discussion in 'The Garage' started by 8_YOUR_H2, Sep 26, 2002.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Can anyone tell me what is involved? As far as I can tell from the pictures on beater74's the outerpiece that has the lugs is removed then welded on the backside of the inner most plate. Any specs?
  2. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Blazen91 was doing this for a while. PM him and maybe he can shed some light
  3. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    I had the outer flange machined off, the hub body turned down so a wheel would fit over and had the threaded holes bored out to fit the new lug studs. The lugs are different between the SRW and the DRW. Also had to increase the size of the holes in the rotor for the lugs to pass through.
    Someone here has had this done and they added a larger diameter flange over the inner flange(star shaped) which is a good idea. The mounting surface of my wheel is almost larger than that inner flange, so it doesn't quite fit right. A 1/2" larger diameter would do it.
    Hope this helps, makes sense. Any other questions, just let me know.
    Brett
