Made it home alive! but...(long, but interesting)
Discussion in 'The Garage' started by Boss, Aug 12, 2002.
  1. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I'll post about the fun at Paragon on the Paragon post, but I had to share this story on how I got home, since it was basically an adventure in itself.
    Well, first, I had a lot of carnage at Paragon. Basically did the "M" trail and the "M" trail extension. (tough trails!)
    Bent one main rear leaf spring built by ORD/Alcan.
    destroyed almost every greasable poly bushing I had. Expecially on my front springs.
    So, I'm towing this 4x8 trailer with my jacks and 5 - 39.5" swampers in there to Philly, which was suppose to be 2.5 hours from Paragon. Almost every bump I hit on the road I would get THE most crazy and scary Death Wobble ever! Now I know how yall with death wobble feel, but I don't think yall ever had it this bad. The steering wheel will shake violently from left to right in my hand. I can't control it. I tried throttling through, but it made it worse, so I basically had to stop the vehicle to stop the wobble. I can't even steer off to the shoulder of the road. There were a lot of pissed off people on the road that day /forums/images/icons/smirk.gif Honking and yelling...
    Anyhow, so this goes on for 60 or so miles. I finally found a Truck stop rest area with a huge parking lot to pull in and see what's going on.
    While Fran (my g/f) goes and buys fresh fruits and stuff, I'm under the truck meditating on how I'm going to fix this "bushingless" problem. The thing is, the bushings at the shackle were completely shreaded where it left maybe a 1/2" gap on each side. This was for both of the front shackles. Each bump I hit made the shackle slide left and right. Caused major play in the steering as well.
    First thing to pop in my head was, "Could Duck tape fix this?" /forums/images/icons/crazy.gif Nah!
    So I'm searching and my g/f is searching the parking lot for something, anything. We found some old shreaded tire rubber on the side. I figure I could use these as the bushings.
    I took them back and cut them up to size and cut a hole in them for the bolt to stick through.(poking a hole through old rubber was a pain!)
    Had to use some rocks in the area to put on my jack to help jack up the frame to remove the shackle (floor jack doesn't reach up to the frame). Crushed a rock in the process...scary!
    Replaced the crushed rock with another rock (all there was in this lot) Put the old tire rubber in there and bolted them tight.
    This took me about two hours.
    Finally got her back on the road and amazingly, the freaking tire rubber was holding up! /forums/images/icons/smile.gif
    I started bracing myself for every bump on the road (and these road has some bumps!), but the truck would try and jerk a little but nothing like before.
    Finally made it into Philly to pick up my sister. The streets of Philly SUCK for driving /forums/images/icons/mad.gif . Potholes everywhere.
    Try to find parking, but everyone wanted $30 or $20 to park for an hour. So, I said the hell with it and just told my sister to jump in and we'll roll.
    So, I'm out of Philly and back on the bumpy highway road.
    All of the sudden, death wobble is back /forums/images/icons/frown.gif .
    Something must've jarred loose in that pothole infested city they call Philly.
    So I do an almost complete stop and then pulled on the shoulder of the road...pissing more people off.
    I go under the truck to try and tighten down the shackle some more. Burned my hand on the exhaust pipe during the process... /forums/images/icons/mad.gif
    Jump back in and I'm off again. Basically, every bump I hit, I just slam the brake right before and the truck will only wobble a tad.
    Hours and hours later, I finally make it home. It's suppose to take 2.5 hours to get from Philly to home, but....
    The whole trip took over 10 hours.
    Truck will be parked until I can get some bushings and a new main leaf for this rear spring. Hope Watson at ORD will work with me on this...the springs were brand new!
    All in all, I was basically "That Guy" on the road yesterday. "That Guy" that was going 20 below the speed limit with his hazards on the whole way. "That Guy" with his hands clenched so hard on the wheel, that it would go numb after a little while. "That Guy" that everyone blows by and beeps and curses at!. "That Guy" that was leaned up on the seat and staring at the road cautiously. That was me! /forums/images/icons/laugh.gif
    Glad I'm home and alive.
    One Positive thing to come out of this is, It convinced Fran that having a tow rig as a daily is not a bad idea.
    At this point, if I can't get my truck trailered somehow to Tellico for the Dixie, then there is no way in hell I'm driving it down there "suppose to be" 13+ hours one way trip, b/c I'm sure I'll get some major carnage down there just like up here.....Thanks for listening.
    Boss
  2. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    /forums/images/icons/ooo.gif Glad you made to home safely /forums/images/icons/grin.gif
  3. CK5
    May 19, 1999
    21,627
    704
    CO
    Boss, this is better than that time you cought your self on fire. /forums/images/icons/wink.gif Glad you made it home in one piece.
  4. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Glad you made it back in one piece. Hope you get it all sorted out in time for Dixie.
  5. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Glad you were able to make it home safe and sound. My truck did not make it home on it's own. I am also looking for a tow vehicle; that is the only way I am going to Tellico. Later.
  6. Boss
    2,550
    Maryland
    LOL! Oh yeah, I forgot about that...I'm a Clutz aint I. /forums/images/icons/laugh.gif
    Bear,
    I really hope I can rent something to trailer the truck down to Tellico without costing an arm and a leg. We'll see /forums/images/icons/smile.gif
    Boss
  7. Grim-Reaper
    7,385
    Atlanta
    GOOD LORD! you have the worst luck on road trips. Glad you made it back ok. Hope to see you and Fran at Dixie!
  8. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Note to self, never park close to Boss as his bad luck might rub off on my Blazer. /forums/images/icons/grin.gif
  9. Donna
    Donna 1/2 ton status
    Feb 20, 2001
    2,377
    Gettysburg,Pa
    Glad to hear you guy's made it home!! I really hate what you had to go through to get there though. We had a slow drive home. About 55 most of the way and the speed limit was at 65. But that's another story in itself.
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    Man, too bad you weren't on this side of PA, you could of PM'd or called and I have some extra bushings laying around!!!
    You going to Neuroc???? www.neuroc.com
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Good lord man, your luck is worst than mine! How did you manage to shred those bushings like that in one trip? Bent springs I can understand, I've done that. But bushings? Anyway, excellent work in patching it up, that was some good thinking and hard work to pull it off...
  12. Boss
    2,550
    Maryland
    Emmet,
    Thanks for the offer, I'll make a note of it /forums/images/icons/laugh.gif.
    Don't think I'll be making Neurocs....looks like fun though. You competing?
    Grim, if aint for Bad luck, I don't have any luck! /forums/images/icons/laugh.gif
    Baddog,
    Not sure how they shreaded. I'll have to take some pics and show you of what's left over.
    Boss
  13. Emmettology 101
    May 9, 2000
    8,126
    FL
    Anytime! If I can help I will, the bad thing is I dont get much time to check my PM's on the weekdn, but if you are heading my way again, PM me and I can shoot you my cell#! /forums/images/icons/smile.gif
  14. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    *note to self: Find another like Boss. Form on-road Bermuda triangle: me, Boss and Other Guy. Wreak havoc across country. Get swallowed by own misadventures. Have legends spread about our fate* /forums/images/icons/smirk.gif
  15. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Choung, I'm surprised Fran didn't have you trade the Blazer for a Lexus half way through that ordeal. What a trip to tell the grand kids about someday.
  16. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Hey Oldman...remind me never to take you along on a road trip!/forums/images/icons/smile.gif Glad to hear you made it though!/forums/images/icons/cool.gif
    Rene
  17. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    damn boss...i bet fran was thrilled about all that
    i can just see you running with your hazards on and slamming on brakes...WITH NO TRAILER LIGHTS!!!
    i bet people were pissed...glad you made it home ok
    hey let me know if youre having trouble getting to paragon...i can get ahold of some trailers no problem...all youd have to do is get your rig here...
    Later
  18. thatK30guy
    Jan 12, 2001
    32,076
    55
    Hey!! If your name was "That Guy", tell them about "thatK30guy"! /forums/images/icons/laugh.gif /forums/images/icons/tongue.gif We could be related by names. /forums/images/icons/shocked.gif
    Anyways, sounds like quite an ordeal for what was supposed to be a 2.5 hour drive back home. /forums/images/icons/tongue.gif Just be glad you did make it back home. You could have stranded the truck and left it there in order to get back home and come back to find parts stolen off of it. /forums/images/icons/mad.gif Not a good thing.
  19. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    leaving your rig on the side of the road is not a good option.i for one would rather sleep in my rig for a night than leave it somewhere.probably come back to find it up on blocks with the windows smashed out.ive seen so many nice cars sitting on the side of the road missing one or all windows from people being a$$holes.
  20. thatK30guy
    Jan 12, 2001
    32,076
    55
    Here's a funny story: A used car dealership in a town 40 miles from me has its store on a very busy intersection and on one of the fastest traffic in the town.
    The owner/dealer had parked a ricer car of some sort out on the front row, which is right in front of the side walk, facing traffic.
    Evidently, somebody or more than one, thought they had to have the fancy wheels the ricer had, so they jacked up the car onto cinder blocks and removed the tires and rims. /forums/images/icons/shocked.gif All around 11:00 p.m. on a busy weekend night. /forums/images/icons/tongue.gif
    Yes, they got away with it, too, and the owner/dealer was stumped as to how someone could do this kind of theft on one of the busiest intersections in the town. /forums/images/icons/laugh.gif
    Last I heard, the owner/dealer was asking people to keep their eyes open for some tires and wheels up on eBay, just in case. /forums/images/icons/laugh.gif
