Magnet in the drain plug?
Discussion in 'The Garage' started by RustBuket, Mar 10, 2003.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I'm building an engine and I was just wondering about any possible metal bits floating around in the fresh engine when it finally does get running. Would it be possible to JB Weld a magnet to the oil drain plug? I was thinking maybe ppl don't do this because the heat may take away the magnectic pull of the magnet? JW if this is a good idea or not.
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    You can buy a magnetic drain plug to replace your stocker - screw-in replacement!
    I bought mine from either summit or JEGS.
    -- Mike
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yeah, i got a magentic drain plug at my local parts place... most of em oughta have em.
    j
  4. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    damn thats a smart idea. lol.
  5. RustBuket
    Feb 21, 2003
    1,618
    Why thank you! :lol /forums/images/graemlins/ignore.gif
  6. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    ive seen a magnetic strip you put around your oil filter too. in fact, it's on page 196 of the new jc whitney catalog. i was thinking about buying it, but didn't know if it was just a gimmick or was actually worth getting.
  7. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Not only are magnetic drain plugs good for initial engine start up, they are also a good indication of engine condition through out its life. Every time you do an oil change you can check for bits of engine that are stuck to it. It won't collect bits of bearing, but it will collect cylinder wall, piston rings etc. /forums/images/graemlins/eek.gif But hopefully you'll never see any of that. /forums/images/graemlins/thumb.gif
