Magnetic 10 bolt!
Discussion in 'The Garage' started by Ignato, Nov 9, 2003.
  1. Ignato
    Ignato Registered Member
    Feb 6, 2003
    32
    Phoenix, AZ
    I have a regular 10 bolt rear and was thinking about putting one of those magnetic differential check/fill plugs in the place of my old one. Considering the location, do you think metal deposits gather up at that location cause problems with the shaft...? The metal shavings would otherwise be suspended in the gear fluid. watchayall think??
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    It likely wouldn't cause a problem, if the shavings are building up enough on the magnet to touch any moving bits then the diff is toast anyways.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Anything with a Gov-Lok comes with a magnet inside the diff cover. Its there to pickup the metal flakes from the clutch discs as they wear.
    A megnetic drain plug would be redundant... It might pickup the big chunks though /forums/images/graemlins/thinking.gif
