Maiden Voyage!!! and a question....
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Max, May 17, 2001.
  1. Max
    Max 1/2 ton status
    Feb 19, 2000
    158
    Durham, NC
    Hey all,
    I had my maiden voyage on the 71 Jimmy (most likely to be named
    Tigger due to the orange color with probably black stripes being
    added if body work is done). Got a set of 35s from Costco. They
    have BFG Muds at really good prices, including mount, lifetime rotate
    and balance, road hazard (hehe). The 35's were 158 including all
    that. $148 for just the tire not mounted, etc. Anyhow, i digress,
    got the tires and took a ride. Was fun to finally get to roll down
    the road. Now...I am starting to find other issues cropping up and
    wondered if anyone could help me track them down.
    The main problem seems to be it doesnt really want to go too fast.
    The engine runs great out of gear, but in gear, I think I can feel
    the tranny shift twice (th350 3 spd), but at the top gear, it doesnt
    really have much pick up or want to go too fast. Got the speedo up
    to 40, but thats about it. Engine is '87 350 with a quadrajet. Any
    suggestions?? What to check?? Ideas???
    PS: 4 wheel drive works as i put it up on a big rock in my yard that
    the jeep couldn't get up on :) Pictures soon.
    Thanks in advance,
    Alan
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It may be running lean due to a cloged fuel filter.
    '71 Blazer CST with alot of rust
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>If you still have the stock axle gears, you need to change to 4.10s or 4.56s to get some speed back and keep the trans from hunting for gears.</font color=blue>
  4. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I agree with Biggray71. Gears are needed because the truck originally came with 30" or 31" tires. Bare minimum, I'd change to 3.73:1 gears, with 4.10:1 being preferrable.
  5. Max
    Max 1/2 ton status
    Feb 19, 2000
    158
    Durham, NC
    It has 3.73s in it.
  6. HarryL
    HarryL 1/2 ton status
    Feb 25, 2001
    139
    Layton, UT (20 miles north of SLC)
    Max,
    According to my trusty engineering calculator, going from a stock 28" tire and 3.73's to 35 BFG's now gives you a gear ratio of 3.0 (actually 2.984, but that's close enough).
    You shouldn't be having probs with top speed just because of bigger tires. As the other fellow stated, check your fuel filter.
    Is the engine timed correctly? Was the parking brake on? :-)
    I say that in jest, but something doesn't sound right. Were you in 4wd High? Low?
    just thoughts
    Harry with 35" BFGs and loving it
  7. Leinie
    Leinie Registered Member
    Mar 5, 2001
    38
    Shakopee MN
    First, I would double check your gear ratio, then I would check your engine numbers. I've heard of people getting 305's that were supposed to be 350's.
    A 305 with 3.07 gears with your tires would be a real dog!
    I hope that is not the case, but check it all out.
    72 K5 CST X 2
  8. 71RestoRod
    71RestoRod 1/2 ton status
    Mar 7, 2001
    178
    Evergreen, CO
    No power or no speed? Are you sure that you’re grabbing all the gears? You might have a bad vacuum modulator on your TH350, or perhaps a vacuum leak keeping you from shifting into third. In second, it seems like you would be topping out around 40 mph.
  9. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    had the same prob with mine when I first got it, stupid modulators. There is a screw inside the end you can turn that should fix the problem, or just buy one for 20$, just make sure thats the problem first though...
    [​IMG]<font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
