Main cap torque?
Discussion in '1982-Present GM Diesel' started by xcucv, Feb 17, 2002.
  1. xcucv
    xcucv Registered Member
    Feb 10, 2002
    6
    I need to pull my rear main to replace the seal, can someone please provide me with the torque specs on the rear main as I do not have any liturature on the 6.2
    Thanks in advance.
  2. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    Inner bolts are 104-118ft-lbs, and outter are 93-107. As a genneral rule it is best to keep the outter bolsts at the low end of the range to help stop cracking from outter bolt hole in main bearing webbing.
    84k20,18:1- 6.5td,400/208,4.10,4",35"s<P ID="edit"><FONT class="small">Edited by carolina custom on 02/17/02 06:04 PM.</FONT></P>
  3. xcucv
    Feb 10, 2002
    6
    Thanks, I always hate dropping a pan but it is done.
